2003 accord v6 tcs and emergency brake light problem - Honda-Tech
Old 09-09-2008, 03:30 PM   #1
Default 2003 accord v6 tcs and emergency brake light problem
My car drives fine and i heard it was a common problem with this year. My tcs and emergency brakelight on the dash stays on when i drive. why is this? and how can i fix this? anyone knows please help me! THANKS!
markvangsta is offline   Reply With Quote
Old 09-11-2008, 09:22 PM   #2
phootbag's Avatar
Default Re: 2003 accord v6 tcs and emergency brake light problem (markvangsta)
Chances are the brake fluid level switch inside the resevoir has stuck. I have replaced a few master cylinders for this, ( the resevoir is NOT sold seperately ). If you unplug the brake fluid level connector, see if the BRAKE light goes out. If it does, you have found the problem. I'm sure the TCS DTC is related to this.
phootbag is offline   Reply With Quote
Old 02-21-2011, 06:54 PM   #3
Have you had any succes in cleaning the resevoir with brake cleaner and putting new fluid back in.
David Evers is offline   Reply With Quote
TCS keeps popping, PLEASE HELP! :) bobbybunz Honda Accord & Crosstour (2003 - Current) 2 11-29-2013 03:07 PM
2002 Accord V6 - CEL and TCS Troubleshooting Question bhbodily Honda Accord (1990 - 2002) 0 10-03-2013 05:10 PM
2004 V6 GXE - TCS, ABS, and Brake Light Comes On nowtype Honda Accord & Crosstour (2003 - Current) 1 12-16-2012 02:43 PM
2003 Honda Accord V6-Emergency Brake Light & Battery Light on romi1216 Honda Accord & Crosstour (2003 - Current) 3 12-02-2012 06:54 PM
Traction Control problems Zani Honda Prelude 5 11-21-2005 01:56 PM
Tags
03, 2003, 26, accord, brake, emergency, honda, light, on, problem, problems, stays, tcs, v6, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
