2003 Accord EX V6 - TCS Light Question
#26
Re: 2003 Accord EX V6 - TCS Light Question
We have a 2002 Accord EX V6, just over 40k miles. This morning we started the car and the TCS light came on, stayed on, and the car would not go into gear. Could low brake fluid cause this? Could it be a timed maintenance alert (in which case defeating the car's ability to drive is extreme)? Recently replaced the brake switch light and it's worked fine for 3 months since that work. Car can't move now.
#27
hey guys, according to my scanner the TCS (torque converter solenoid) indicator comes on the dash when there is irregular voltage to the torque converter solenoid. I have the same problem and I can't understand how changing the brake switch fixed your problem. please, someone with knowledge, elaborate on this issue.
#28
Re: 2003 Accord EX V6 - TCS Light Question (H2290)
I also have a TCS light come on almost everytime I drive but it only comes on after a few minutes of driving and sometimes does not come on at all. I can always get rid of it by restarting the car. I have an appointment to get it checked out this weekend. No other lights come on at the same time. I have read that if the Check engine light comes on as well that the transmission might be an issue if the car is throwing trans codes. Any help or knowledge on the TCS would help. Also, is there a way to just disable the TCS light by fuse or something similar. I could live with out TCS...
Thanks...
Update, The light did not come on for the service guys ($98) so they told me to come back when it does. They said no codes came up...
Modified by cbenko at 12:58 PM 8/23/2007
Thanks...
My 03 Accord TCS light would come on randomly initially as well and I could not determine why. Hooked up the code reader and no code came up. Recently, it came on nearly every time I drove the car but I noticed that it comes on every time when I press the brake pedal. I ordered the brake switch to replace the stock one. As it turned out, the old brake switch still works but it was out of alignment with the pedal. Reseated the brake switch got rid of my TCS light. Moral of the story is, diagnose the problem first before replacing any part. BTW, You can turn off the TCS system from the dash switch but you cannot turn off the TCS light because it is triggered from the ECM. Once the TCS light is on, you cannot turn off TCS.
#29
#30
Re: 2003 Accord EX V6 - TCS Light Question (bfos7215)
My dealer replaced the ABS module and it was fixed-I had the same problem. The first time I took it in they replaced the brake switch, but that didn't do any good. The ABS module costs about 1000.00 if it's not under warranty-mine was still covered. It's about 1000.00 for the module through the dealer.
#31
Thanks...
Thanks...
#32
on my 03 Accord Ex, the TCS, and the little triangle to the left of it (both in orange color) come on after driving for a few seconds. The brake light also is on (in red).
I'm taking the car to have the brakes checked first make sure the pads and sensors are ok. so what next? should I replace the switch under the pedal?
If ABS module is faulty I would think the ABS light would be on. I tried the ABS and it is working. For those who may need an ABS module there are places that rebuilt your old module for about $300. Just do a search on the web.
thanks,
03 Accord EX
thanks,
03 Accord EX
Cpt Marvel
06-25-2013 04:18 AM
