'08 Accord Coupe Fuel Sending Unit Replacement
Fuel gauge has been stuck on empty with low fuel light blinking. Fuses checked OK. Did the dash check process and fuel gauge worked during that test. I have now ordered a replacement fuel sending unit and am ready to install.
Looking for help with how to access the fuel sending unit for replacement on my 2 door Accord. Access from the trunk or under the back seat? Thanks!
Re: '08 Accord Coupe Fuel Sending Unit Replacement
it is more than likely in the trunk you have to pull up the carpet and what not ane worst case scenario just drop the tank
That would be a worst case scenario. It is a task to just drop the tank. The pump access cover is under the rear seat like a 92-95 civic. You'll most likely find a varmit has had dinner on a wire once you gain access. If it is actually a sending unit I will be surprised.
Sordz
02-18-2010 12:20 PM
