04 honda accord won't start, clicks only. - Honda-Tech
Old 06-24-2012, 08:57 PM   #1
Default 04 honda accord won't start, clicks only.
Help! I have a 2004 honda accord V-6 3.0. that won't start after I parked it at a shopping center. No cranking. Just a click sound and nothing. Battery is fine (tested). Some one mentioned a fuel relay. I don't know where it is situated on my 04 accord v6. What could this be? I suspect the starter or alternator.
mohmandem is offline   Reply With Quote
Old 06-24-2012, 09:24 PM   #2
Default Re: 04 honda accord won't
Have you had anything done to it recently. Have you tried a jumpstart?
newtohonda03 is offline   Reply With Quote
Old 06-24-2012, 10:54 PM   #3
What was the battery voltage?
If the battery is fully charged (~12.6 volts), it might be the starter. I've heard that light tapping on the starter body with a wrench/hefty object might help it start once more so you can drive it to the shop.
gwiffer is offline   Reply With Quote
Old 06-25-2012, 07:32 PM   #4
Thanks newtohonda and gwiffer. Here's an update: we were able to rule out both the battery and alternator. We tapped the starter and eventually got it to start. The culprit is the starter. Sometimes it would start, but this must be preceded with some "cajoling" with a hard object. I bought a starter $105. It is cheaper online of course but I didn't want to wait. Will have it installed tomorrow and will update.
Old 06-27-2012, 12:36 PM   #5
dpetro1's Avatar
Default Re: 04 honda accord won't start, clicks only.
single click is almost always the starter. the "bristles" inside lose contact. hence why banging on it sometimes helps them to make contact.
rapid clicking or slow cranking is generally a low battery.
dpetro1 is offline   Reply With Quote
Old 07-04-2012, 11:47 PM   #6
Perhaps the case for Honda's but when the starter went on my Subby it was a rapid click. Don't mind me though, first Honda, live and learn
ammo303 is offline   Reply With Quote
starting problem vmtacheene Honda Accord & Crosstour (2003 - Current) 2 08-31-2015 03:24 PM
2006 Accord won't start, Ive read all the threads and tried several fixes. LeviKC Honda Accord & Crosstour (2003 - Current) 5 07-17-2015 03:39 PM
Car won't start or turn over glockoma818 Honda Civic / Del Sol (1992 - 2000) 1 12-21-2011 03:58 PM
1990 Honda Accord - Car Won't Start, Press Brake Pedal Click from Shifter photostopper Honda Accord (1990 - 2002) 3 12-25-2010 08:30 PM
h22 accord won't turn over. misledyouth Hybrid / Engine Swaps 7 03-10-2003 05:44 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
