Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
04 Accord V6 Brake Issues
Old 07-06-2014, 11:03 AM
juniornapeahi's Avatar
Icon2 04 Accord V6 Brake Issues
I'm having an issue with my brakes. I replaced the brake calipers, brake pads as well as the Master Cylinder. Now, my TSC, ! and Brake dash lights are ON. When I try to bleed the brakes, I only have pressure on my FL and RR brakes. The FR and RL brakes have no pressure. Not sure what the issue is, did not have this problem before I changed the calipers and brake pads.. How do I know if its a bad proportioning valve or something else?
Thank You
Old 07-06-2014, 02:49 PM
BLKFLSH's Avatar
Default Re: 04 Accord V6 Brake Issues
This link might help to get the lights off, but the "no pressure" issue sounds like the master cylinder or proportioning valve.
http://www.driveaccord.net/forums/sh...78&postcount=5
Old 07-06-2014, 02:59 PM
I replaced the Master Cylinder, so I sounds like it may be my proportioning valve. Is there a way to overhaul or restore the proportioning valve? Or it just needs to be replaced with a new one? Is the proportioning valve the same as this:
http://www.hondapartsunlimited.com/a...er=46470s5te01
#26 - 46470-S5T-E01 JOINT, FOUR-WAY
Last edited by juniornapeahi; 07-06-2014 at 03:06 PM. Reason: forgot to add link and verify if its the same part
Old 07-17-2014, 11:24 PM
Icon2 Re: 04 Accord V6 Brake Issues
I replaced the master cylinder and the proportioning valve. I now I have pressure on all 4 tires. But now when I press the brakes it doesnt release the presssure and all 4 tires lock and my TCS light comes on. The only way I can release the pressure is if I bleed the brakes. When I do bleed the brakes with the car off, the pressure applies to the brakes and when I let the brakes go it also releases the pressure on the brakes. It seems like I only have the problem with tires locking when I start the car up and the TCS lights come on. I thought it coud of been a problem with the calipers, but those have also been replaced. Any ideas of what else it could be?
Old 07-18-2014, 12:21 AM
VeeSykkz's Avatar
sounds like ABS problems. Have you pulled codes?
Old 07-18-2014, 12:53 AM
Yes, I got NO CODES FOUND, not sure what else to do. Thank you for replying
Old 07-18-2014, 03:05 AM
johnsc2235's Avatar
Tow it to a dealer. It may have an issue with the vsa...
Old 07-18-2014, 07:41 AM
Was hoping to avoid taking to the dealer because I have no money to tow it there and no money for them to check on it.
Old 07-18-2014, 09:03 AM
Is there a way to just disconnect the ABS and TCS on the vehicle? and just have regular braking system. I dont care about the ABS or TCS at this point. I just need a car that can take me to work.
Old 07-18-2014, 01:25 PM
BLKFLSH's Avatar
This is a TCS reset procedure. Don't know if it will help.
Old 07-20-2014, 02:52 PM
Tried that still having the same problem. I thinking I could have a bad ABS Modulator. Ive pretty much changed everything else with brand new parts.
sebTeggy
12-03-2011 04:33 PM
jofat91
05-14-2011 10:40 PM
kuja396
04-28-2008 09:57 AM
byronl
01-22-2008 12:55 PM
VADER*
09-12-2005 06:38 PM
Quick Reply: 04 Accord V6 Brake Issues
