Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
03 No driver’s side air conditioning
Old 08-10-2009, 07:01 PM
emsman1's Avatar
Default 03 No driver’s side air conditioning
I have a 2003 Accord Sedan LX 2.4L I4 w/ 82k that is having an AC problem. I can get really cold air from the right-center vent (passenger) and the passenger vent near the door. The driver side vents blow only warm air. If I cycle the temp to hot, all vents blow hot air. I can cycle the output from floor to defroster, but the air is only cold on the passenger’s side. Any thoughts?
Old 08-12-2009, 08:37 PM
HONDAPARTSMANMIKE's Avatar
Default Re: 03 No driver’s side air conditioning
i would rec have the freon recharged its most likely low an freon. usually what will happen is when the freon is low the pass side will be cold and the driver side blows warm. bottom line is have the a/c checked and recharged. good luck
Old 08-15-2009, 08:01 PM
soon2bdropped's Avatar
but how so if this model dont have dual climate control? im very curious.
Old 08-24-2009, 10:40 AM
phootbag's Avatar
Due to design an inefficient syestem will cause your description. Either a low charge caused by a leak or a failed receiver dryer which is plugging the system.
Old 08-25-2009, 08:01 PM
^ very well said phootbag
Old 02-19-2014, 12:03 PM
Powerboss's Avatar
So I have an 03 accord 2.4 and it's blowing hot out the drivers side, cold out the passenger side. I just checked my freon level and topped it off. NO DIFFERENCE.
Any suggestions on what to do next? (Besides take it into a shop)
Thanks
ACardAttack
Honda CR-V & Element
10-15-2016 06:57 AM
aust 97 coupe
01-03-2009 05:21 AM
alscrx
10
01-03-2008 06:57 PM
DOHCVTEC190
07-20-2007 07:34 AM
Quick Reply: 03 No driver’s side air conditioning
