03 Accord Radio No Sound?
I have an 03 Accord 4Dr EX-V6. My radio has no sound. The backlight and everything else works, just no sound. Can anyone tell me if there was a recall on this or an extended warranty? Or maybe something I can do to fix it? Thank you!
Re: 03 Accord Radio No Sound?
http://www.automotive.com/2003/12/ho...lls/index.html
There might be more websites that you may want to kind of google or something. I just did that real quick this morning.
Not asking for code. I see on the display the radio station or CD track, but nothing from the speakers.
I did talk to my dealer, and they want to charge just to look at it. Since I am out of warranty (92k miles) I'm assuming they'll just want to change it out and a new radio will probably cost lots of $$$. Am I better off just buying one from ebay and installing it myself?
Got it fixed!!! I pulled out some fuses to the radio from the indash fuse. Retyped in my code and no I have sound.... Hopefully this doesnt happen again and if it does, lets hope this is the solution. Thanks for the help everyone!
How did you fix it? I have the same problem - everything is fine, just no sound and I am certain the speakers didn't pop. I went to Honda and they tried to charge me $750. I'm not paying that since I am pretty sure I don't need a new unit. Can you tell me what you did?
Check amp turn on wire, yellow/green for Element off radio harness. Cut yellow/green and car side run to yellow/red or switched fused under dash. Amp will have hard start with radio pwr button but not with every key turn.
Mathew J
09-07-2008 05:30 PM
