Worst Cooling Fan Problem Ever!!!
I posted a similar thread previously when I thought my problem was fuse box corrosion. I have since done quite a bit of testing, and hope this post will help others who have tried all of the basic solutions to no avail. I feel like I have read nearly every post on the internet that exists regarding cooling fan problems, but haven't quite seen this:
(1992 Honda Accord DX, with A/C)
So basically it seems the whole system works when the fan timer is grounded to the blue wire. So what is stopping it from working when thermo switch B is jumped? Is thermo switch B only supposed to show 5v? Is the fan relay supposed to show 97Ω or is that too much resistance? The relay exactly like it for the windows shows the same resistance. I did swap out a different fan timer (had access to one), and there is no difference. Swapped relays and there is no difference. Bought a tone generator and have no clue how to use it yet, but I'm checking online videos. Considering the whole system works from the fan timer successfully, this must a wiring issue right? Specifically the blue wire, especially since that is the same wire that goes to thermo switch B. Where do the two wires from thermo switch B go to? If I know where they go to I can bypass them and see if I can get the fan to come on.
I know there are a million posts about cooling fans, but everyone else seems to solve their problems with a new fan timer and/or a new fan relay. I think this is wiring. Any help would be appreciated.
- Fan motors work (jumped both directly at the connector and they both spin when powered).
- Fuses are good (No. 2<15a>, No.39<15a>, No.8<7.5a>). Tested both sides of each fuse with a test light.
- Fan Relay clicks when 12v added to the NO side. Multimeter shows 0.00Ω on the circuit side (12V in the picture) when powered. Multimeter shows 97Ω on the NO side when uncharged.
- Radiator fan comes on when fan relay box terminals 2 and 4 are jumped with a paperclip. Fan comes on whether the car is on or not when the paperclip is used.
- Voltage is NOT detected between terminals 1 and 3 when A/C is turned to ON with fan ON and car switched to ON. A/C is not charged currently however, though that shouldn't matter (?)
- When ground is applied to terminal 1, the condenser fan comes on, seems strange.
- No voltage present on terminal 3 with car off. With car on, the test light illuminates.
- Thermo switch A (green arrow, closest to radiator): radiator fan comes on after the car is shut off when the two-wire connector is jumped with a paperclip. Shows 12.28v with voltmeter when car is in ON position.
- Thermo switch B (blue arrow, closest to firewall): radiator fan does not come on when the two-wire connector is jumped with a paperclip. Shows 5.03v with voltmeter when car is in ON position.
- Temperature gauge sender (red arrow, middle sensor): Gage doesn't move when this is connected. When the sending wire is grounded the gauge shoots toward 'F' immediately. Pretty clear a new temperature sender is needed, but it shouldn't stop the fan from working when switch B wires are jumped (?)
- Condenser fan comes on when condenser relay wiring is jumped with a paperclip. Wiring shows 12v with voltmeter (located near the drivers side headlight).
- Condenser fan relay passes the continuity and voltage tests applied above to the relay fan relay.
- Fan Timer Test passes on all 8 pins:
- 1-Yel/Wht: Battery Voltage (yes, test light illuminates)
- 2-Yel/Blk: Battery Voltage (yes, test light illuminates)
- 3-Yel: Battery Voltage (yes, test light illuminates)
- 4-Blk: Continuity to body ground (yes, voltmeter changes from 1Ω to 0.08Ω)
- 5-Wht/Grn: Voltage (12v on multimeter, but test light doesn't illuminate)
- 6-Wht: Battery Voltage (yes, test light illuminates)
- 7-Blk/Yel: Battery Voltage with ignition switch on (yes, test light illuminates)
- 8-Blu: Connect to body ground (yes, both fans engage when this is done).
Re: Worst Cooling Fan Problem Ever!!!
I think you have your sensors mixed up, I believe the blue arrow is the coolant temp sensor going to ECU while the thermoswitch is actually further back behind the distributor, right by the thermostat. It should have a green connector similar to the one on the upper radiator hose. Are you actually overheating at all?
Is the car overheating?
The photo with the green arrow is Fan Switch B, not Fan Switch A.
Fan Switch A is not pictured in that photo, it is located on the thermostat housing – connected to the lower radiator hose. With the ignition to RUN or START, if the coolant temperature is above 194 degrees F at fan switch A, then the switch will close, which should turn on both cooling fans (radiator fan and A/C condenser fan).
If you were to disconnect the 2P connector to the coolant temperature Switch A, and jump the connector with a piece of wire or small paper clip, then turn ignition to ON (II); both fans should run. If both fans run by doing this, that would indicate the power and ground sources, and relays are okay.
Both Switch A and B are normally open type of switches, and if working properly should close when the coolant temperature is above the respective temperatures.
Sorry guys, yes I referred to the switches backwards. Switch B is the green arrow and it works when I jump it with a paperclip; the fan comes on after I turn the car off.
The blue arrow shows 5v on the multimeter but when I jump it, the fans do not come on. The ground wire shows continuity, the lead wire doesn't. But if the lead wire is open then how am I getting 5 volts?
When I jump the blue wire from the fan timer, everything comes on. The relays click when connected to a battery and they show continuity when tested.
Yes it overheats, I'll probably have to change my head gasket which I'm fine with that.
Everything seems to work, I'm starting to wonder if it is the ECU?
Thank you both for your reply, I'm hoping to solve this because I haven't quite seen this problem online yet. All indicators seem to be pointing to ECU, is this a logical conclusion?
I think you are talking about this location for Fan Switch A:
[img]data:image/jpeg;base64,/9j/4AAQSkZJRgABAQAAAQABAAD/2wCEAAkGBxMTEhUTExMWFhUXGR8aGBgYGRcaGBoaGhgaGxgYGh oeHSggGhslHRgYITEhJSkrLi4uFx8zODMtNygtLisBCgoKDg0O FxAQGC0fHR8tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS 0tLS0tLS0tLS0tKy0rLS0tLS0tK//AABEIAMIBAwMBIgACEQEDEQH/xAAbAAACAgMBAAAAAAAAAAAAAAAFBgMEAAIHAf/EAEAQAAEDAgQDBgMFBgUEAwAAAAECAxEAIQQFEjFBUWEGEyJxg ZEyobFCUsHR8AcUI3Lh8RUzYoKSFkOi0iRTwv/EABgBAQEBAQEAAAAAAAAAAAAAAAEAAgME/8QAIBEBAQEAAgMAAwEBAAAAAAAAAAERAiESMUFRYXEDIv/aAAwDAQACEQMRAD8AW2RMUWw2H3OqEgXTAvffrQ3AuaSApCk9R cU4YTLhpkiQeI+hqBfcydDkklSAU/CIt1jnVFrItMKQErH3lr0pB9L044/DgJPTak9GagPqSFInlKBwmCVJIJ6TWTM+j2AyMKSUOqw6Cr4VJ WsQf9QKdKknoQR8qp5bkCmnT3iY5EEFJHMKFiKuYHNsRp0oSto Di2WElXmrTMeQqNGYvOlXeJJjwoIUFKUpZACVaQNRMeYE3oltu NWcc6R540/iEnuRCEmJtKjOyQfiNGuyHYjQpGKxxlaDqQ2dgQZSpfMjgOFMe AwiMOjvHAkKA2+yjonmrr+is9v8div3XvmzCDEwDqSk8eXFPv0 rt1HLsw9ov2hMtpUEXULHoeEDjMEiucjN/wB81n4VTYEzcbeU0m4dVyo78z86ssYktqBT5ec8DXOce9atOGV O2neDCuYNXMYwhXAe1D8rHejvmj4h8STx6KH48fOrreLFyod2Z jSvaYmAfzrVg0qY3s8oLK0rsdhxFaDNXG5QsakER0jaCKdWDJI 0lU/dvblF5oe/kCnHSkNqAPMEAdbirOloJlrLeoJbIQkgqKySpQgWAHE3MC208K LDGAtgLWXFIiAqLiVaDHMajziassfs9cSdXegchpJAtG+ofSmL IuyDTAEqLrhvrXz5J5D1rOtSFjC41KvCqyuRt/ep8Zhe8TCEi+9rU/IyhJ30+QH51s7l6UmQNSeXEfnR5NY57hezp0EJGlU2KVRHvYcb Vd/wnGKbCdZB431SOfQ07IaTHgCYPTeq6lqbuJ08U8uo/KjyWEZOWYxl1T6TIgSg7GOJPAxF7UzFtvGtd28kpVuNtSDwIPH 6GjaXAsSDIIoU/gyhQKbA/D0PFJ6GtceeMXg567gsXh8T3Mp38Mk6VDgodDH4VfyzO1PKLY3 TuoXT6Gm7PMOcVhlJQSl0C14kjdB8/rFKmX5f3LYTEKO9av5EMaEcUm/MfiKp5pg23IKk+JIgEC/MRtx+tAszzpWHRquZMTy5k/rcirWWdo2nEi88OvrVpWMt7QvMQgwtH3FzH+2Tb/l6U1MdpmSJ7vSfu8jS2pxtfER1qJ3AosUxPCCR9KE97aYwPEFI jkONKpydSruEgH7IuT0phDKw6pQIKSkDSQJSoHcQJMg8TwFaqT B1cedVQR+4BKFBBCVaTIi4ibfI3O9AJExsfkacFg6VJEeJWpR4 knnQLF5cBNqxJZ7QSWeZrKlLaxa3rXtaRly/MPGNSfCqBBFwePWJpsy/FRwtxHSuf4bFa8RpkgAAFVxYSq3IxRfB5qVFMrF02A3/AFwqlVg3mOLKiUg2G5rkGIw5K1cTqMnmZ+lN/anOwiUNm6uP65UotKVIM1I1ZBg30JBGKWkfdTeeQGqRfyrpWUY YYVvv8S4pTkWCiIbB4JAAGo8THTzXOweEhsYp4aQP8sHb+f8AL 35UK7X5o7iQSlUNJ4XlRmPaa1OhRlHaJ9/EJ0NqcSFHQgRNpJVexIuQTyqT9rGcr7tTDBlBSC4RJInUkpPLY gzzFTfs/wACpogm+lMA+ZH4CmUdmGQtS0pOpe8kkegO1ZtakcAw5ISJMmm 3Juxr+ISCohtJ4mSqP5fzIroOJ/Zzh1OJdjQQZISPCfNJsPSmrA5QhAEGfO9XkvEj5R2BQ2Qs4hwq H3QEDyPxyDTG5k7Mp1NpkfCVjWmeh2B9KPuYMfZ9qrLlMhQsdw dqPLTmKiWdPhgInYQC2fIxM/qK3SCDAOhX3SZQry5entWyiE2N2zuDfTy9PpWEAQhRlJ+BXEHl PP61WJIzpWTqEKG4P18utTuNgiCLVSXJts4jY8x+R+RqfD4kKE 7cCORG4NZsOo7oMHbgfwNSa63cEiDVJDkHSd6CzEI0nUPhPxDk ede6pqQrm1V2UkEpJiNp5UINxTZZVKfgPDkatpcDjZHHceYrMw ebKSiSpX+kTBoQrHrQfA0COZO9Iq0ElJDg2MBX0B/D1HKg/asBr+L9lQm33uXr+dFsLj/CQ4yrSqZ0mbGpFMB9kojVExPNP0JH1rpxvxikTK8MrEIC3PhVc pFzEER+uVZisGG1BKUgJJseCif1tW2JYdwiipuQk3jgD+RonhO 0+HeTpeSEmIJtB/ClUGKUypNvDvBjcc6871bXiCtSOIPxDy50fVk7Lif4ak3M2MX6 VKjKkoRdouLFgVK1Wj7KdptTg1DgH0Opsbn5V6rBmYjp68qp5d hFjFT3ehCgbTcKiduBp5y/CDuwlcKVFyYM+vOhEvFYNSDBjmIIIPkRY0OxLKlAaUkzJHMgbm N6bM2yt2NKEgoQCTzvEm+89Kny3CJVoVoJjZQ+zaL05qtxz8ZY TvWUy4vDBK1DkT9ayjGiEuUFwgjQE+Dn/EsPkTVDD4/ujKZKq6872NYcKrABQAOkEm3KTA9Kmy/9neERfutR5uKJ+QgUejyu1xdGHU4ZIKlE8BemXs/2QedWnWypLc3KhpsOABveu0YbK20J0pShP8qQkfKphh+7vANUB ZxfZN19AR3gbbsISJMDgNgKI4LsFhUJAUkrI++okf8AEQKMqdJ H6isbUecVJExg0t20QOGmAKuIcHACtBiSLKuDWj40QRdJ+VGFa 7ytFNzdNjVdD1b99QkiH/Q8ax0BQg/2qB641DcVCHwazSgdBSSk7fL+1VmXBdlWxug8bcPMVfxI1p6ja gOYTAUn4k3HmOHqJ+VbncFXy+Smf+42YPUcR6i/nXinQFJWD4HIB6H7J/CqJxY1Nuj4XAEq8z8J9DIrT7LrPLxJ6A7eyqkOh9IHjUE+dUns WhSgUBRjc7CosM+HEpUQJI48CLK+lWnY0mseqUSsY6Z0pSj5m1 VP3hSiCoyetbJxEqA51UcPDrTIlzDkEGhzosek0awuASgFTjkR ukDxAnYEHpJMxHrQnNGe6A8QIWnWk3B0qJiQbimxazAvxFXsNi h3yuv1TAPy+lLDeNCSTyr3A5iNaSTxv67/AFNU9im3H4FK0lKgCOFc87Q9jFgfwTuodNzFdIxL3w9R9P7iq7 wLhShO5MDzIufRM+4pTnWXZOoIKlBQ8Sogx4QYHTYfOi/Z8OqBWl1R0qgJNiTANzx3mPzp2zXLwlvRpF/COk0t43JXGkhSCU3m3AdRsbCqUYlSW1K0OKDbuvUgCYVtMcvL5 0fyzBlSf8zxSYtw8+PtSc7iFpc7xQ1b22md9tqO5NnzSlE64Ue CiBA5AbRatzPUYoviElAhfhTtqid6mSAYtpPsPPoaA4rNxilaW lQlBtNgs8dJ5cL9aI4XPL6MQmD94Wq9VNsTkba1FRJkmTWUUY7 spBBkc7c6ynUhwr4IsI5ipCs86Gh28jjw5H8qlW8aLGtTqcV51 Kw8bg7daopdPGve+oqWHyRMbfr51G2/PGtA/wA9qpYhehXQ/WjSJlytsPiYOk7UPD9aOOceNVS2+otqjgdq9D9VnXw4iDuPpVJ h87HcUaRlGIqniXNKp4H61GjUo2BNS4zD6WzrIHG5FZKRnEGai zFqJ67VVOeIRZpGpXPgPWtWsa44D3hF/hA4VT2qD4e7b7PFPiR6+IfMRVk4oFbLnBxOk+ZEj5g1Q77Ti/50KHsZ/Gq7Ln8Ji/wuAeyyK3WRnL3o1pn4XLeS0z9ZoqHvAfKlnCveNz+dEf8AE/hRR55QRAFzYVimNGXYWJ4VZyXNmEvDUoFYSpYTxtsbiJvNBMy8 CFKKh78+dLDgVrDiRfcKJjyjjWoq6ljsc2w1/DUSVp1qWQNSpPhbG4BJJk0JzPBOODU4tKXIFvFERtqJiR6VznH dpHvhWbogpAsIEkDoLxYbUYwvbptSzq1BJ2URA22UkE+4rXV9s qXaFS2SW91G5jgOHvVHA5oUkFQgT8uNdAbaw2Mb0rCFjcfaHUp O6T5GgY7Ddy8240dbWtKlsrg6kgydKtiehg9avHrpeRwL2vDgp ElMEdZtV7IGlJhw3URCUzsCfEfMn6V5h1YYJKu8gEzpWlQi+0a Z3rbD55hGSR3hIJmBMA+WofSuWt9CmLOtyVWSkeEcVKM/gCfSquIIVb9R+hUGV5gnE4gKQD3YBAMHcR/7fKrGd4dQMJFlC/obVr2AXENIcOkJkkcB+PpQDMeyRQC8nxRcg725dRR/LsQ426pKhBsBsRHXiDam39yC0QQOgmnjuiufZU33wOn4xxsJB+ 0eA5E0awGCWslDglKd5mfQ8Ki/6bcbxBW0vQkmeqfvCIgiedNmXMEJM3PE2ueddL0xFUM6fC2EBA 2ABrKvjDEVlBwml2D0qytz160LeXvW+BxVtJ9KaotF/lWd/QzGPaV9D9a3D1ZK+p2vNYWkpO9UC/W2EKtdhIrNMe4d87HcVIvEVpisNDl7T+v15VqvMmGf9SulzUlz LmVkzEDrWOlttZ1qERNBX87ecsnwJ6b+9U3kAAzcnib1YtHMV2 jUfCwmB94/hQ1SFLlTiys9dh6VUaetU7L4v5VYlwYmIjl/SrCXrJoM0rwg7Dmff8a8exoA1z4Uj5/nRhVMRi//AJKT90OT5SAKiafgMg8JcP8A5K//AEn3oQlz41rMavDvFpJV8z8qsMY9J1KSCZEJAI4bEWnSPITFaA thczaZHePKAmVBMjUSQEpt/KPnVDH9rXHNSkgpQLg6ZKQONxHy41ezrEYTEhhDWHSlbaSFLVZ Str9TYm+5NK2eYhWH8AUSFJN7eIcRbhVi1A/manPF3ilxtcb842HtUjGYrUqDxpewjoG1o/MkUQwmKAUI3P6mkNc7wpW+pQWE7DmIAj6zVMJAEFU+QiiGZJhE 8efnQRx3bcmpCeXHEMfxGVqQJmJsR5U+9j+34B7t0AFR/wBhPT7poXlmA7lltx8halCUtwPANgD948b29ppiyzNkONjUzqa P2kwbDjHLrUDs/hmcSjWjSVJG8AqR580/q1c+zPDvtKWFiY8RPAjmk8qNsNOYYjE4VfeMxeLlI+6tP3f15M 6m2cYySAQvimRKeZTzHSmzVLhHyTOXGmkYkNJPi8QW6EFCCLKS kAkm/Eces10RjOkOJSrVII3FxeLSOIrnuYsLZUUqhPJUSD1G5rMDi1q BKXTa0gcd+Jt7Vz8s6xrx+m7PMu7wJUAnVM6xY2vfrajeHxwbS hSkjQR4l6h4TyIP4Vz/ACzOXVqUhTmuBIPAgEAGeO5FHMrwDMpeduZMT8IPM8AfOtSiw2 ZYougLWkpSRsdz/Si3cC2mwF/6ULYxKSYBow24DWqI90Vlb1lDTkjrnCq4XFWEoKrb1YRlCjvam 1mK2J8aJ4/jVbBBSrCiLqmmkkKVS87mxRPdJmbzwA6VkmVGDQganFgDzqtiu 07SBpZTqPPYUorddcMuK9OFToAFOLRDFY557/MVAOwHD1qmy0lPnWyXJT5VTxGJ8VCEi+BWmNfsOtDULKjcwPn7 VWx2bNJcbSpcfhPM3gGInr0qS+h884/XAVDj84baSRck2kR7CmfCIwjrYQEJSRe4BVfiomdXntVTH4PQk pKUlHKAUHlI/XnVSTXM5WY1qtwGw6WqdnHa5BXpHAc/P5VPisqYWCkhSDwIVMfykg+xv1oFi+z76LpV3g4QIV/x4+k0heDmoEKGr+/69xWjqlJX3jQ/mHH06UFw+OUgwbXpmy3CKdAKUm/Q38qCF4zNwjxn458Im4jnyoYnEBYASlJUogdbnc09jshhgQ5iS J5Sb9dIur2qlnPZ9lK++ZbCdIBUBYcUykbAzE1VF/DZTqUUiNI5ced6r/u+hyBeN6sF0p2NibijGS5J3kuLNzVuJC9kL2KaBYKFEKhaNUKb G3eKB+x1EnpWqOygwriCtYcWRMRABki17m1NeQrYYLitUlwd3q j4EwZUbXExseA9C+cOoaR360pdcSNKAlJkqOytMQI3Jm3ATFWg l4hsOBaFEzESLiOKQfLc8abcA2hCGimEhKIAi3HalLAuKkICTr n7I3HKBx6dKPZEw+6tRU6EpTASFhakmeEp+Hbc07+Dn5E0Olol 1qx+2gXSocbbg/WqrObraX3rZCQDqMQEkngOQ4eQNb4PFKcWUhBRAJJMlNjG4ExO x6ioH+7adMONd4ghRaUSBcSdwACRHGs+V3uNXhM2U5Duca0owC ofGkbgj7aTQE9mihKtConeAIO8cZn0qJtQEYzBGBu42Ps8yOae lM+AzBOITrbsqPEiYE808/Kt2b/XOXCQy2GnVFcpTo0pKbajqST8gbjiRRJefIKEpRAVeQk2TJ2qh mWF/d570hRJ8IudY58hHLhSpg8MpK9YVMm8/Wjjxw266blWaGADuTY3n15+dGkZkpO9COyuDhOtabx4QfqaMPJ SeArrrni0M861lCFYb/SayhYC4nPmWvhgmgeP7TPOWSNIoaGwK8Waw2lYRqVKyVHr+VSu piPUe1/w+dUUuwatYlzwg8j9d6CqFyKiXiahSkqvUantJsL0gSS8Utkkf rhQpWYtolSpIF+pPATwrRxxxwwLTvwEdelLGaOErISZSLTzPE+ VBbO5u+Z/iEAnYAADytVEyTJMk7k1GQa9CjURjK88eZgA6kjYHh/Kdx6U3YHtOFiCSlREX/UH9WpEwquJFTYl4cqgdW25clYlJEDjBoklCdI1G14HHp1PCkjJ M3xCVJQBrQdwqbdQrhT5gmVGCELcWdkISVH2AtWcaaLylpcOvh ICNlKiY6nj61E12iQ6ru8N4QCkFREFQJuUDeOtadoMifedQjEK bYb0kw68hBKoMANglwxx8O00xdmMhy9GHGJL3evpKk/wtQDhEEAIcSDAGnxCBbjSxy3OkmX4BLSkqdTddwpRtbnzPnQP9 oOZnUhlHgQQVCIlV7Ej7u8Dp5UxZt2iQ22dMKMGEje3PlyE1zX Me+cX3uISQpfHgeQB6DhvU4f5cbbtCk6ioalAieXWmdGO/h90jY/EfwFAhgdTqIMJPxdAASSPQe9FMsyxx5XdteI8+AHM8qs16UOY5 qloSDB2txNT5J2jCrEW48qZnexGBZQH8bLhQm6EqVBvMkJufLa vcFmGSLOj93Q2DsShaPUrG1OAU7O5f3zgW3pCkgysRIlJsOZid udXsoyzELUnQkpSEhIIMBQSIJmqY7MpUA5gMTp46ZDiZgjwq+J G+96rf4ni8O2hGIK2yiQhQhSDJGyhYzyMHpRx4q034XJ+51rUI JSBfkCSfwrlHauz7zkgjSm4M7IFMmb/ALRFIwzrS3EuLUkpRBGqVCATxAEz6Uk4lgpwUAHxQJjiogb1q9 LUfYfPXWHgAYQeew6eRp1wmYqaX3qVabyTsCT02A+QFLOT5Enw hRgyJ6Tzp9V2YLKUuMr7xSL6FAaVJi4HWOe+1CGGHmsW2SEoUs fElSUq4fGkKBHE8KrZTkqbqcbw5IV4dKFINuKgFAT0il558NLb xOH8IUbp+4sbp8jf6U09+lzS4myViSOR4i1b+MCK3k/dHoo/1qHFZg02JUN9pVf0EUIxWYaTCNShzMW8rX9aBY1rWrUXFSeKh8 rTRrWDi86kyE26qv8ASspd/dj/APYn3r2jTheU/WrmIqNLE7mrScOALGD7mkKrbaib2HWrTzw0gCTBE7Xj6UNW/fSo34Gq2KUpI4x9P6UIw4bM2tgkjyqtmWaNpEkGg2VYPEOBamU FemNXiQmCrVpHiI30q/4mgGOwmIX3y1JVDKgl0iNLZKilIMGLqBEiaCv5nnKlgpEISdxN z50FU+nnWzmUPgpSW1AraLyQftNBCnC4OadCFH/aeNWcnyF5+S22VgEAmUpAKp0iVEAqMGEi5g2qSq2nV5czR3Key 2IfALbDq0/eSk6P+Z8I96O5IjFYfSy02A+vUtJDLSntKdQUNa0lSUgtLsIuF VmJGJxCO9eW66gSrU4tSwNKkJJAUbQpxAt96imIEdlUt/52IwzMbp7zvnB/sZC79CRW7WGy9H2sRiD/AKUt4ds9JV3i/WBUGNyXEI0/wVDUpKBtOpfwJUJlBVwComq7GGUoKVB0IICzy1atKT56Ff8AE0 Iy4fOWWk6m8Iwidtep5fnLhKfZIodm3afFuwC+5oOyUnQjy0Jh PyoQ8w+6kupQothQQVD4QqJCPYTRXBZcS0gEALCjMkfCflyqqV 8NloJDgJEXIG/Wrr60JI7tfxAEEA6VfkekUUDIQ2nbVMHTe1zJIqHIMq1FOoaTJ CdVuJhRB4R72qzVcSYLKnn1AOkhsiDBVPuTPtFOSMIhASFpCkA pHiAI5bHiKvJw2kBMXHAWHnVPHvhAvde4A3HXp5mteA1R7S9ns IfH8MqA1AAX+hnbbciruEaQ2yU4dIQgD4uJPPqeprzKtLyNSzr lUXvcKsR6ia8zPDOIBJFuc1WYoWM6xZUlSVcRuTeefn0qo52VQ ptOlZC4udwTzjyg2oZm+JC3kt7hHiV57gem/tRzLcwBgGI9Kx3Gy+52ZxzCg5hHbzJKTpV7Gy0/qKc8i7SYwNxjWUuINtQEKPPUnY/KrjOMSQBwGw/Kpy8FbkR9elXnR4qH/RmW4xwPMkgpMrZConpp3HpFaONhhpKFiCBGneefp1om5ljbriF qCm1i4UmRbf4geQNvlUOPxSAx/wDKUXtOykpCVSOJUTHsDWtlGYH9mcOy4XtQ0uRqSJJGm+r/AHJnVPKeVdAyx/vm5V/mJOhz+YbK8lCD71zfLsxdWdeHQ3h2EKBW4swCAQdLjhlRkfYR7 U6YLMEJWnFNmcO6NKjfYH4oIBBSqbRtNawAnbDAhp4ECEvCSOG tBEq9QR7HnW+SJLZW0o3SZHTh+VEO2TK8Q802ygrDUlwpuAVxp E84E+tE2MApzT3pDZAJJUADcyIvYXi/LzrUZoZiGQL7g3oe6yDwp0bw2HAKUqCyRFyCPkKQO0KMQ2tISC G5hWmSuZtIiQNtqKYHY/Kne8VoB02I47gGPQ2rKmTj8aLaHPRIjzFZWukXm8PbUbngK9dW kC9q1YBFbrb48TtWEB4huSTWwBKI4j6UVXgpvGwvVNYgK8o+dS CcPmiGGcQhTbTy3HWFJQ8lak6UIxQWsaVJgguIFzss2MGLWUZ5 hG2msO4FlLoc/eFIWUtoL/8ADALRaKnO5QhtwaVDxExPGpjY0gk8diAUn0It5igeJCSfCkeY oJzZz9hY7paioN4It4dxKV2eXgDh3GCCme7Usg6ogKROylGoch UhDCmlLw5UpYUpvEodU1ASU6kLZSXEOC4IkSCNyIpdwmHTpnV4 pgJjhzmjGFw3rUjL/irSEKUytfeodcSxr1FXcrdQ8FqWd1akLSZMnvjverL+cYdBWlq 7QZAbQUkAqVjG8QpG1oSCiTY93xkSDZyxxWw+tT/9MvKE8fWnBrHsQwjFfvBxUpViW3QhCXtWn94Diy8CgDwpBgJKy VRFr1PiMYk4R5vu221rdbUkNoUNSUB7USZIsFJ5fEfQTjOy2KF wgK8jf5xUriHAB3iVNx05DnWbK1KM4fFMJZRhyFaS0pKnNZCUu rKXdRY7vWopWhpvUFfCgxvcThkG0yPOoVKSv41KPr+IE1Yw7GH AgKCfJSqYBxjAEAEVfwmDmCTF6HYLHpaSVd+nu0iSVSocZ2E8B bczXuA7Z4ZwGZTcgSIkcDxiaZyFhgczF1A0heqByEjleKGJwrm LKm2nmmtJ8feKKSo8tVyT6f0pLztqZ75CZ2kiI59aiyphDzOpn Sl9IlxlLiTqA+02pJ36Gj/Tlc6U69n3Luz/AHYa1kCFaUhpSSkBQKdWpQkmCeFEV4ULQtClkhQ6Smw2PmJvzp T7JYVQcS645pAII1FM7xpSNxyJN7mKc2k7nnHyHGrhudm5vRaH Z5lCgnSCSSkqAAUfCVXPHah2b/s/U4QpjEFs8ZSCCOO0X86ZBK3gIslWtR4eJJCUjmYVJ9OdjCKKYS 8N2UU2IWtxfXwfQCpf8BX/ANty/JQ/EflTsbChjyv4gI5VSLS/je/bbUC2rSnYp8U7DVAuLDiKHYLOAoFAGrSATEGytjHEGKfwqdx60 Ax3ZRtT/wC8NqKFlOlYABQoTNxvq6g1Xji0AxrzDqEtup8KZ0plSdM7kAE Qa8YxDbbRYaUQgq1aSZvEbnmNxxq/mnZNDohZNuVr8LwfpS/kGUFHeFxshQVCdQNh0nfffpWuM0W4P9jMWk4ju0OkFVyEmyiOE 7VczXGrD621K1aVWVMnSfEEzyEgR0pazDEs4eXEoOuABpBEmII B2HU70OyXEkrWru+7StWpKZKgnmNRuo2mt8fbFPeFdi9Vc2dXr BSYkSVEnhaI9q1wzgIFWcV3YRqc+FN6eUZisjFWuVk8wYHp4ay qn70s3LRTNwOQN0/KKyjtvouvMAWAqw1hUgSsxUOKx6GxAuaCYzHLXxgVZINtXs3zd AGhsetKmJxKj4RxPv0q44jlVN9MVm3TIhxbiSngYEDzoc0walK ZVai+VZbrVHDc1ktslylSzOwHGmEPssCANShUeKd0gNt250Fxd rb1v0PYq92rI2R7mKHp7fOA/wCWCP5yPwoHmR0iOJ/X69KotMz71nypyOj5X+0MGNaFD2UPwNNOBz3C4gafCTxA/FJrjK0hJ0gjVE+1VMOypbsSdQNiN56UzmvF2XNOxrbiSphQQeE CU+qZ+hFcv7SZDjMMSXAS3Pxtk6PXin19zTVhM2xeDIDkuJG5u Y6aoieh5im7Ke1GHxI0EjVF0mJ9RxFPV9DuODKWTuSau4ULgD2 rpfab9nLTkuYYhtRvp/7avQfAfK3SucYzDP4d5Lb6CkzF4gjaUq2I6is2WNS6ud0QAVG5 BP8AtFFslYlxKgrRBBmY52nrHzqm+sKKRF0oKD1uYI+fyoivEl STqjUUoSLbJbSEJHsKzhdPw2WJabD7ykrXICUpjw9SZ+Q50TRn qEpXqQo6iSFH4UyAI6ARXK8BmDybd6sp5TP1mmFjMbArSo8jYp 9heepHtT69L2dclfSsrXOkKUNE7lKUJTq9SkkdCKPoTaxBrm6c 4TwWPoamRna0jUk286vL9LHQniYM0IUsax5H6UuN9pXl2F+u1X MLiCVpk3iPka1MFHkvEVOy6YJt1oe05IFTYZ4JKgratVlI++Bx FQYhpK0148hCjY9amKIFqzeOKctLbjYnSoBQ4ggEH+s/WqOaZGYK2FGQZLZuCBwSdwfr0q9iDLh8/qf7VcZXtSvoJluIkCipGtJQdiI/r5ihGMQG3TGyrj1Nx+udXsO7W/jHqhT2V4tKilGJSpI2VCxI8oMHhHSvKMO4BpZ1KTJO9ZRrTnLs AEngJqlhXysq4ARA+skQeVT5jiElBCTJNo+ta5Sx4J6n5f0Hzr Fabd1H2onyPysfrVTGpgTY+VEcXgSBqPHbpyFCCyZgmaykeCw/GmzK2QhkqPG/sP70PyzCJKb3PCDcelGX0FTelI5D861AGaOJ43/Khz0SZ2FMLOXEjxGBVlrBYdO4mnFrm2YAqVIk3ollmDIRJBm52 NPv+I4ZFtKfVQqRGf4b7iPcVeP7WkBxi9xRXsp2acQ+XnUgJgF FwZJnccCBwPMcqcms6wqrd2PQ1aRisIoRqKek1eH7XkBYFQSS3 JlSlKGsWlZKtGvoBFuCR0pH7a40BbKUp7t1vUV6bFJUqyQeIB1 e9dXOUML+FaTYcuBkVXzLs7rUVlDSzpghaAtJO2qOGwmINhcUX jygl7AP2e5xjHWlrWEqbR9omCqIBtEcd7bGmnFYfD4tBbdQkg8 DYg80ncHqKFrwC0YNxhlpLKyUnSCVNEBwLUE8UzcQbeLehGLxC 2UJdWTqDYkXAKp5Uy7LqvvpFnXYtbUrZJcRvFtY/wDb0oA2m+166Ng84AQlSjKFBMK2+ISB58PSvcxyVjEAqAAUeIs fXnWc+xrSQ08hHxmeifxPCjOWp1pDyYUkWUgC4HHz4HrFBs+yV 7DEKQlS0cVJ+z5gXHntVbIMS8VqKUhR0k7BYuRJggj160NHLEZ UlaAobHYjb0pcYwRQ73ckkQQeJBMX8oqTs736X/4izpJI0X036UWxQSnFoVzbV8lJ/OpDGAwnhE+9EGlpDiAOG/rahX+IBRgWAqzh1AGRvWp0zTcMO2rZYBofj2NKgNU8bULQ4qbV P4ib1q8pjMnbcmTasxeYFpNzc7Cq7+LS0lS1mAnel/LwrEvB1wkSYQncJTw9eM0EXwsqOo+f5frpV9C6q5jmeHwyUhw6 QpUAm8mL7fWgn+Od8vS0ClAN1EiVeUbDrSBvPG0FnWVQtJlA+9 cBQ9r+lD8E/Ioi86gIQlaSoKkWjl13paw7ulZSeBi/Lh8qZfgsMqXa8qih21ZSAnLuyTZbCnNQURcg/gaCfuXdKWlLkp1eE/Waa8Zm3d4ZSw6lRCbCBIUdtuVq55iM2B2PpXCOlEMY654UklQ5 8v7daibYlVQZQVL1LUeg/H8KMMtAXrcC0mxgDbbb8OFXGsVERdX1qphWFOEhPqaYsuyYIEq MdTvW5AGDAPucQ2Oe59zYexrRXY9pZlxx1w8ta49kwKZi+yjhq PWqj/ahCTHhT9acn0bfgEjsFhwZDTn/ACV/7V6rsSkEwlwat7g2HC4qbFftBbSrSVmeiTW//XaZ+M/8TRnA/wDSDK+zP7uoqTqNxuBsOFqKEiTqRI6gfjWrHa9CikakkqEgEEG D6dDV5rN0LF0g9RBq8eK2hGY4ZOmW0wYJ8MztYR50NyTM8ZoJX KCDGlQPzBps/gq6GtFYPikz86ss9VaoM9o1x40BQG5G/rVkZjhnRCrTzFRYrBg/E2PMWNVXcA2QkAlOkQAbjrM+dXf0JM47ON4loICyEiI0EcNhBG 35Cg7WWZhhVfw1pfb+6rwrHkTIPkTV97L3EmWVADlJn+9SYnNH 2I1grSeISoxEfFAtvR1/C3w/aEmzram1clCPbgfSp8C60VqcaRpV9tSBBP8ANFj61A3nzDibgQ fUVNgFNiVNeEHcpsPyqw68zPDrcU2pOjwGbCCRImedLPajEFpS FEKAvcAkDbcjamTHs4guJcbWggJgpI0k3mZEya0OZqFnWiOoEj 3FWatKeDzkK+0POjWDzMHjPrVteCwb19KJPEeE/KheJ7EpnUy6U9Dce4INZ8afKDbWaJSJUoAcyahxnbRpIhvxq/8AEevGlDGdk8Sn4iVjmDP1vUWEyJU3JHn+VBS5tnKnYSom5kyZ p27KoDidSXU6kiyVHSTa8cD8qC4PJW7SnV53ok1laQfAAmeVqt GFPt3nAff0puloR01T4z5WA9DRPsnik6IiVH8LfWnHIcAhgKIS LmVDiZ386BDDtHEuKZSEtzYAQP8AUY2F52pQnmL6NCdX2QT5Wp ew+GV3QxHBSyCL8bj04e1QvlTz8we7BJgTfgJA4RRpyP3ZSCYH C2x4Xp3sYibxFhWUIaxVhesrQwEzo2FLrlZWVybN2RD+Cn1+pq +vasrK1BTN2eSNKbcJqbHLM7msrK6/GL7UUfD70OxqBewrKyuHJ0hS7QNiEmBN+FB2jWVlUQxkKiQ4Sb yL+lT96r94Ikxp5n7rh+oHtWVlMSLshi3C9pLiymNtRj2muj4R Z5msrK6Rmi3ChuLArKytMKOGWdcSaMN1lZVfRC84w6CCSlM84E +9b9kf8oDqfrWVlc+Ptr4vYwRiSBYaAYFhueFb4gVlZW6yW88b AEgAHmBf3rzKHVfePua8rKuKpiaNqr4tAjYVlZRTA8b1cYO1ZW Vyrov5kojVFvCdv5aXsH/lK/lNZWVtlFgvC4kpseYsaq9pXlFJlRMxMknjXtZUgYGvaysoT//Z[/img]
My car is like this picture though, is there a third switch which I am not seeing(?):
Wow!!! i removed the air intake and hiding under the ignition coil was a little sensor going into the thermostat. I jumped it with a paperclip and the fans came on! Good call guys. But then what is that TW sensor for then? It also shows 5v.
It tells the ecu what the temperature of the coolant is so it knows how much fuel to spray.
