Won't Start when hot, searched, not main relay, PLEASE HELP H22 SWAPPED WAGON
Old 04-30-2006, 08:27 PM
BLKCivicPorscheStyle*'s Avatar
Default Won't Start when hot, searched, not main relay, PLEASE HELP H22 SWAPPED WAGON
Ok so it finally started getting warm in ohio, I picked this car up to be a daily driver this winter and it ran fine but lately it seems that the car will not start when it is hot. for example I wake up to go to work car starts fine, drive to work turn off and right back on its ok but if i get out and go back to it twenty mins later it wont start it has to sit for an hour plus cool down then it starts. many people said it was the main relay i cant even seem to find this in the car shop manual tells me its a 7 pin connector (nothing found)
Car has an engine start button and to start it has to be on position 2 with the key it seemed that it wasnt getting fuel at that point all the time so we metered it and all seemed fine but hooked up a relay direct to the pump (positive, ground, acc., and to the black/yellow (pos for fuel pump) this still did not work.
I don't realy know what else to do when i get in the car hot it just cranks someone help fix this car its such a bad *** daily driver i wanna keep it.
Old 04-30-2006, 09:06 PM
YeuEmMaiMai's Avatar
Default Re: Won't Start when hot, searched, not main relay, PLEASE HELP H22 SWAPPED WAGON (BLKCivicPorscheSt
could be any number of things
test your ignition module
test your fuel pressure regulator and fuel pump
It could be main relay but that usually is not a problem on 5th gen cars
Old 04-30-2006, 11:27 PM
accord-pro's Avatar
year and model ??
yep it could be the main relay ...
first off, when it does not start , you need to verify if it is lack of gas or spark,,
if lack of gas i would look at the main relay first,,relay located under dash , left side,
if lack of spark,, ignitor, coil,
Old 05-01-2006, 02:46 AM
OuttaGas's Avatar
i saw alot of main relays on 94-97 accords and even started seeing them on 98's last summer
Old 05-01-2006, 04:22 AM
In a Junkyard near you.
Ross 2.0's Avatar
Get the area around the car nice and quiet. sit in the car with the windows up, turn th key to on without starting it. Watch your check engine light, when it goes off you should hear a click. If not your main relay is bad.
The main relay is under the drivers side dash on the outer wall of the car. Someone on here can post apicture of it, or mabye i have one to post.
Modified by MooGoCow3 at 5:34 AM 5/1/2006
Old 05-01-2006, 04:37 AM
Ross 2.0's Avatar
Default Re: (MooGoCow3)
It looks something like this.
Old 05-01-2006, 05:09 AM
thats the problem the car has no main relay I pulled appart the entire dash there were two behind the cd player and one under the dash left side that controls the heater. year make and model is 94 accord wagon with a 95 JDM h22
Old 05-01-2006, 05:11 AM
Ross 2.0's Avatar
Unless someone hacked up the wire harness during the install it has a main relay.
Old 05-01-2006, 06:01 AM
i think it was a hacked up harness...unfortunately...
Old 05-01-2006, 06:04 AM
95exrv6's Avatar
first up
sweet *** ride !!!
my buddy had a 90 wagon with h22 swap in her
cl interior
all the bolt ons and was making like 220whp with her
in your situation, I would bring it to someone
if you did the swap urself, and you hacked up the wiring, it's gonna be a bitch to re-wire but you need to !!
pretty sure that u cannot run her without the main relay
Old 05-01-2006, 06:06 AM
accord-pro's Avatar
Default Re: (BLKCivicPorscheStyle*)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BLKCivicPorscheStyle* &raquo;</TD></TR><TR><TD CLASS="quote">i think it was a hacked up harness...unfortunately...</TD></TR></TABLE>
if the car has been starting , and it does not start only when hot,, nobody hacked the harness,, otherwise the car would not styart in the first place,,,,,,
relay is under dash, located on the rt side of the steering column,,
car will not start at all hot or cold if relay is missing or wiring harness has been cut
Old 05-01-2006, 06:16 AM
Ross 2.0's Avatar
Mabye it was relocated for space reasons? I don't know, I just can't mentally justify removing or moving a main relay. If it has been cut out what is replacing it?
It's really buried in the dash your not going to find it for the first time unless your on your back looking up into the dash
Old 05-01-2006, 10:34 AM
I really dont know how it started before, I pulled the whole dash off and got on my back seats were out and there was no main relay that i could see, i looked hard I want this thing fixed. So i unpluged positive at the fuel pump and ran a relay (pos, neg, acc. and pos to the fuel pump) that way any time car is on accessory the fuel pump is running. So it cant be a problem with the main relay. Also replaced rotor its getting spark.
Old 05-01-2006, 10:48 AM
Ross 2.0's Avatar
Honestly not knowing about this hack job I really can't help you. I can look at the honda electical manual but that's not going to apply in this case.
Old 05-02-2006, 06:25 PM
Ok so today I tried to replace the fuel pump with a walbro 255 I had. The car ran worse (too rich) then the problem still occured. I pulled into chick fil a and 20mon later tried to start the car. when car was put on accessorie i could hear the fuel pump kick on but the car just cranked and cranked and cranked. I'm totally out of ideas i dont know what to do someone please help.
Also if anyone wants to purchase car as is I have put 4 new tires on as well as new bumper lenses, new clutch and lightened flywheel, oil was just changed I would ask only 8000 which is what i paid for the car.
H22A Accord SiR engine swap
auto. to manual swap
DC Sports header
Injen intake
AEM tru-time adjustable cam gears
Unorthodox Racing main crank pully
Bosch Platinum spark plugs
Magnecor spark plug wires
STR fuel rail
Tsudo front and rear strut tower bars
JDM/ true HID headlights
Mugen grill
Versus carbon fiber hood
JDM auto-folding side mirrors
Apexi WS coilover kit
Brembo big brake kit conversion
Skunk2 extended racing wheel studs
Brembo cross-drilled rear rotors
Suspension Techniques front and rear sway bars
18" custom powder coated Racing Hart C5 wheels w/Nitto Neo Gen tires
Imported custom Apexi exhaust
Sparco Torino racing seats
Sparco steering wheel
Sparco shift ****
Forbidden Motorsports short shifter (not an adapter)
Momo leather shift boot
JDM SiR Tach gauge cluster (so the RPM redline is correct for
the engine)
The speedo. is from a manual Accord so the auto. shift select lights are not there
custom molded piller guage pod with air/fuel meter and boost guage
Ferrari sounding air horns
The car was just repainted, no dings, dents, or rust.
This is, in fact, the wagon that was on the cover of speed, style, and sound magazine.
Old 05-02-2006, 06:53 PM
Ross 2.0's Avatar
ok heres a question for you. When you turn the key to on what does the check engine light do?
Old 05-02-2006, 07:57 PM
bdby1977's Avatar
i work at an iport salvage yard it does have a main relay above left kick panel it a b** to get to get down by kick panel on left side look straight up
Old 05-02-2006, 09:39 PM
ur car is nice
Old 05-02-2006, 09:51 PM
momstaxi's Avatar
Default Re: (YeuEmMaiMai)
i say its a faulty ignition control module, ive had same symptoms and it was always the problem...like a $70 dollar part and a 15min job...
Old 05-03-2006, 05:01 AM
the check engine light comes on it has been since i bought the car unfortunately its the "JDM" engine and no dealer has the thing to check the codes.
Old 05-03-2006, 06:54 AM
95exrv6's Avatar
dude who did you buy this from ?
bring it to a honda mechanic ( not a dealership ) in your area
buy a 12 pack and make a day of it ...
don't sell her she's magical !!
Old 05-03-2006, 08:53 AM
Ross 2.0's Avatar
All you have to do is jump the 2 pin connector at the right side under the dash (if that's still there) And every dealer has the 3 pin adapter to allow the PGm tester or the HDS tablet to communicate with the car.
If you need more instructions the procedure is in one of the stickied threads at the top of the forum.
Old 05-08-2006, 06:56 PM
ok so heres the deal the car is no longer for sale its a peice of **** but i love it and want to fix and keep it (i feel like a DSM owner) I found the main relay good lookin out to the guy that works at the junkyard. We resoldered it and that did not work. We are in the process of replacing the thermostat but i dont really thing thats it either bc my temp gauge never really goes out of control. I have an SCI-L and the rest of the MSD ignition set up ready to go in the car that fixes the spark problem but I run into another. To run an external coil you have to have a cap that can do that. Prelude's in america come factory with an external coil so MSD doesnt sell a cap to do this for the H series but of course the JDM engine has an internal coil!!! so what cap do i get to do this will a b series fit or can i use an OEM replacement american Hseries? wtf?!? jdm sucks
Old 05-08-2006, 08:21 PM
momstaxi's Avatar
for the cap, use a 99-00 civic si
Old 05-09-2006, 07:45 AM
Default Re: (momstaxi)
sweet thanks
Quick Reply: Won't Start when hot, searched, not main relay, PLEASE HELP H22 SWAPPED WAGON
