How do I " CLEAR" the MALFUNCTION INDICATOR LAMP (Check Engine Light) ?
Old 10-25-2006, 01:39 PM
62maxx's Avatar
Default How do I " CLEAR" the MALFUNCTION INDICATOR LAMP (Check Engine Light) ?
HiYa, all... got a 98 Accord LX 2.3 4cyl. .... while I was "TRYING" to find the fuse for the rear brake lights, I had the vehicle running and pulled the under hood fuse #5 (20A) labelled "STOP" (I figured this was for the stop lamps, then thought 20Amps?) anyway I pulled it, it was OK. I then went to the drivers side fuse box and pulled fuse #9 (inst. panel,Back up lights) When I pulled this fuse, the "chimes" began to sound so I said "whoa" and put it back. This fuse was fine also. But then the D4 green drive light was flashing on & off (while the car was in park) and the the damn check eng(malfunction light came on) !!!!!! I shut off the car for a while, the D4 light corrected itself, but the check eng, (malfunction) light is constantly on...any way to correct this problem?
Thanks very much for a GREAT Honda Site!!!!!
Old 10-25-2006, 03:45 PM
Hehonda's Avatar
Default Re: How do I " CLEAR" the MALFUNCTION INDICATOR LAMP (Check Engine Light) ? (62maxx)
To reset the ECM, with the ignition switch off, pull fuse #13 (clock backup) in the passenger side fuse panel for 10 seconds.
You can also just disconnect the battery cable for 10 seconds, but you will then have to reprogram your radio presets and clock.
Your engine and trany may operate a little differently after a reset until they relearn your dirving habits.
Good Luck
19Honda91Sedan
17
05-10-2020 01:20 PM
dansaleen_04
07-22-2013 11:19 AM
Cdeese910
10-25-2012 07:56 AM
Terry36
Acura TL, RL & ZDX
11-19-2007 11:19 AM
Quick Reply: How do I " CLEAR" the MALFUNCTION INDICATOR LAMP (Check Engine Light) ?
