White smoke from engine after Seafoam treatment
Old 11-08-2011, 06:27 PM
Mishako129's Avatar
Default White smoke from engine after Seafoam treatment
I just used 1/3 can of Seafoam through the PVC valve of my 91 accord (320k miles), and after (or while) I did it, white smoke was coming from the engine bay. It seemed at first like it was coming from the valve cover but then I saw that it was coming from below the VC... It did fix my idle problem (thank God) and it also made my car run better, but i'm kind of surprised / worried about this smoke from the engine.
But what could this be? Is it a bad problem? I read on the internet that it could have been a vacuum leak.
Thanks.
Misha
Mishako129 is offline
Old 11-08-2011, 07:01 PM
chikin pickle's Avatar
Default Re: White smoke from engine after Seafoam treatment
Dude.
Read.
The.
Can.
It does that.
chikin pickle is offline
Old 11-08-2011, 07:07 PM
Mishako129's Avatar
Originally Posted by chikin pickle
Dude.
Read.
The.
Can.
It does that.
Really? I thought it was only supposed to come out of the exhaust pipe, not the engine itself.
Old 11-08-2011, 08:29 PM
phootbag's Avatar
You spilled something
phootbag is offline
Old 11-08-2011, 08:44 PM
Mishako129's Avatar
I really don't think I did because of the powerful suction of the PVC prevented it. I was using a measuring cup to do it.
Old 11-09-2011, 04:15 AM
djkurious's Avatar
It comes out the engine also. Done it numerous times...
djkurious is offline
Old 11-09-2011, 04:46 PM
It comes out the exhaust, if theres a leak it comes out there too. Porbably a cracked exhaust manifold.
Old 11-09-2011, 05:05 PM
nus_dogg's Avatar
Or worn out rings where it goes past the rings and down into the crankcase and of course you'll see it come out some other places such as valve cover, etc.
nus_dogg is offline
Old 11-09-2011, 07:10 PM
MM Gruppe B
MAD_MIKE's Avatar
One of the neat, and sometimes unexpected, outcomes of seafoaming a vehicle is any exhaust leaks, or blow by, will show up as white smoke.
Add the recommended amounts to the fuel and oil, this may help a sticking ring, but if a ring or cylinder is bad, or the valve guide is sloppy, the white smoke will find the path of least resistance, be it a bad ring/cylinder, valve guide, or gasket.
MAD_MIKE is offline
Brembomaster
Engine Machining & Assembly
15
04-09-2019 10:25 AM
J3ST3R562
11-18-2013 01:01 PM
jaypapes12
06-13-2013 02:22 PM
spaceman spliff
07-22-2009 11:26 AM
Quick Reply: White smoke from engine after Seafoam treatment
