Where the hell is the MES connector?????? - Honda-Tech
Old 03-01-2003, 03:31 PM   #1
New User
lahight's Avatar
Default Where the hell is the MES connector??????
Can someone please put up a pic or give a detailed explanation of where exactly the mes connector is on a 95 EX? Please, there so many conflicting descriptions. It is definitely a two prong connector correct? Please help.
lahight is offline   Reply With Quote
Old 03-01-2003, 05:14 PM   #2
GimpyAccord's Avatar
Default Re: Where the hell is the MES connector?????? (lahight)
If you're reffering to the service jumper (to check codes, set timing etc) on most 5th gens I've seen that is below the glove box usually in a little blue holder (unless you've had it out before and just left it hanging). If thats not what you're looking for please clarify and I'll try to help!!
[Modified by GimpyAccord, 5:15 PM 3/1/2003]
GimpyAccord is offline   Reply With Quote
Old 03-01-2003, 05:32 PM   #3
carolinaACCORD's Avatar
Default Re: Where the hell is the MES connector?????? (GimpyAccord)
yes, gimpy is right. its under the glovebox, in another connector. just look up in there and pull it out. its only a 2 wire plug.
carolinaACCORD is offline   Reply With Quote
Old 03-01-2003, 09:29 PM   #4
Chiovnidca's Avatar
No, he's after the memory erase signal (MES) connector. It's used for eraseing SRS codes. It's on the left side of the dash near the fuse box. It will have either two gray wires, or one black wire and one white wire.
Chiovnidca is offline   Reply With Quote
Old 03-01-2003, 11:10 PM   #5
Default Re: Where the hell is the MES connector?????? (Chiovnidca)
Funky!!!! and now I know.
no SRS equiped accord unfortunatly in my garage... or fortunatly that is.
Old 03-02-2003, 12:29 AM   #6
New User
lahight's Avatar
anyone have any pics or a more detailed description, i have been breaking my damn neck under there and i cant find it
Old 03-03-2003, 02:13 AM   #7
New User
lahight's Avatar
please, anyone?
Old 03-04-2003, 02:06 PM   #8
New User
lahight's Avatar
bump
Old 03-04-2003, 02:48 PM   #9
Default Re: Where the hell is the MES connector?????? (D16Chiovnidca)
wow, i never knew that. i always thought of that as the MIL service check connector.
Old 03-04-2003, 11:09 PM   #10
New User
lahight's Avatar
I know someone knows the answer and has time to waste....
Old 03-05-2003, 11:37 AM   #11
subnet's Avatar
Here you go...
MES 90-97 Accord at right bottom edge of dash.
[img]c:\mes.jpg[/img]
Here's the URL http://alflash.narod.ru/honda.htm
[Modified by subnet, 2:40 PM 3/5/2003]
[Modified by subnet, 9:01 PM 3/5/2003]
subnet is offline   Reply With Quote
Old 03-06-2003, 02:02 AM   #12
New User
lahight's Avatar
Default Re: Where the hell is the MES connector?????? (subnet)
Thanks!
Actual Location of MES Connector On 1993 Honda Del Sol shailoche Honda Civic / Del Sol (1992 - 2000) 7 09-19-2009 12:14 PM
where is the MES ( memory erase signal ) on a 4th gen prelude tdo Honda Prelude 5 08-30-2005 12:24 PM
Locating/Identifying SCS service & MES connectors help needed. 98 accord Russ713 Honda Accord (1990 - 2002) 5 04-01-2004 12:13 PM
Connector Issues, Please help lahight Honda Accord (1990 - 2002) 2 03-09-2003 06:49 PM
mes connector? lufern Honda Accord (1990 - 2002) 5 12-11-2002 03:11 PM
Tags
1997, 2001, 98, accord, civic, connecter, connector, erase, find, honda, location, memory, mes, picture, signal
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
