where to fill up ATF ?
Old 09-17-2003, 08:36 PM
ddua's Avatar
Default where to fill up ATF ?
My car is an auto, I am thinking to flush and replace the ATF.
I've found the Dipstick, but can you guys tell me where can I Fill the ATF from ?
Also for my car is the drain hole right under the dipstick ?
Thx for the help.
Old 09-17-2003, 08:46 PM
crafty's Avatar
Default Re: where to fill up ATF ? (ddua)
You fill it up from the dipstick hole
Not sure what car you have....
I have a 94 accord
The drain plug is under the tranny (points towards the passenger front tire)
Its the only bolt that you dont need a socket to loosen.....It has a square hole that you use w/ a ratchet (no socket) to remove.
Btw if you use the search function you wouldnt have to wait for a response.
Old 09-17-2003, 09:48 PM
ddua's Avatar
Default Re: where to fill up ATF ? (crafty)
okay i did a search and someone said something about filter
Do we have tranny filter ?
btw do u use hose to pour the atf ? coz the dipstick hole is waaay dooown there
Old 09-17-2003, 10:36 PM
crafty's Avatar
no filter
use a funnel
let it drain for as long as possible....when i did mine i jacked up the drivers side so the fluid drained toward the opening (passenger side)...
and the plug is magnetic (stock) unlike the oil plug....make sure you wipe off the excess gunk
Old 09-17-2003, 10:59 PM
ddua's Avatar
Cool Thx A lot for your help
Old 09-18-2003, 01:12 PM
ddua's Avatar
btw we turn the drain bolt counterclock wise to open right ?
I couldn't open mine, its so freaking tight !!!!
any suggestion?
Old 09-18-2003, 01:21 PM
iam7head's Avatar
leftie lossy, use bigger tool
Old 09-18-2003, 01:31 PM
crafty's Avatar
Default Re: where to fill up ATF ? (iam7head)
I thought it was going to break when i was trying to take mine off....
So I got the torque wrench out.....actually made a crack sound when it finally started to loosen up.....freaked the sh*t out of me!
It's not something you want to break.....good thing with the whole "no socket needed deal"=you cant really strip it! (I hope)
Old 09-18-2003, 05:10 PM
fe519's Avatar
for the newer accords, like 98-02, the atf refill is not through the dipstick (V6). There is a bolt you have to remove, its behind the dipstick, kinda down a little
Old 09-18-2003, 05:54 PM
soysauce021's Avatar
Default Re: where to fill up ATF ? (fe519)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fe519 &raquo;</TD></TR><TR><TD CLASS="quote">for the newer accords, like 98-02, the atf refill is not through the dipstick (V6). There is a bolt you have to remove, its behind the dipstick, kinda down a little</TD></TR></TABLE>
for my 6th gen (i4) i use the dipstick hole. didnt know that about the v6's tho.
Old 09-18-2003, 09:20 PM
ddua's Avatar
Default Re: where to fill up ATF ? (soysauce021)
I know all the v6 has its own bolt to fill in the atf
and for inline-4 it's from the dipstick hole
Old 09-18-2003, 09:24 PM
Spooch69's Avatar
Question: How many miles should you wait to change you ATF?
Old 09-19-2003, 09:08 AM
crafty's Avatar
Default Re: where to fill up ATF ? (Spooch69)
I think Honda recommends every 30,000??
Old 09-20-2003, 05:17 AM
integra dave's Avatar
soysauce why are you biting my avatar man?
Old 09-20-2003, 09:36 AM
DrunkNRacer's Avatar
Default Re: (integra dave)
no.. 30k is too short.. change it every 100k
Old 09-20-2003, 12:27 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integra dave &raquo;</TD></TR><TR><TD CLASS="quote">soysauce why are you biting my avatar man?</TD></TR></TABLE>
haha i've have this on for the longest time.
GSRWSU
Acura TL, RL & ZDX
08-26-2009 06:08 PM
soon2bdropped
12-11-2008 03:27 PM
88CRX-CRB-UT
04-13-2007 09:51 AM
Bugs1066
07-20-2006 10:50 AM
Casual Gcode1
01-15-2003 06:19 PM
Quick Reply: where to fill up ATF ?
