Camber, caster, toe & a dropped 1997 acura CL
Old 08-26-2009, 08:02 PM
Gnate's Avatar
Default Camber, caster, toe & a dropped 1997 acura CL
Here's my baby
(PS rims are for sale so PM me if you are interested.)
I put new lowering springs on the stock struts cause i'm cheap right now.
I went to get an alignment and realized I badly needed a camber kit. What setup would you guys recommend for both the front and rear? I was looking at ingalls stuff...
And my caster is way f*cked up, here is my alignment read-out. Do you guys have any advice?
I'm gonna drop by a frame shop tomorrow to see what they say about my caster and if my chassis is messed up from previous collisions before I owned the car, because my front bumper is clearly a different color black than the hood or side panels...
Thanks in advance
-Nate
Old 08-26-2009, 09:38 PM
19Accord97's Avatar
Default Re: Camber, caster, toe & a dropped 1997 acura CL
Alot of people will tell you dont need a camber kit.
However, I had 3 alignments by different shops and still began to see some tire wear. I have an Ingalls balljoint camber kit for the front and a Wicked Tuning for the rear. Both have been great so far *knock on wood* and the shop had no problem installing/adjusting them. However, alot of shops wanted $200-300 to install the front ball joints but I found one that did it for$80 total and they've never pressed out Honda ball joints before (b/c its easier to change the entire arm). Other than that the only - about the ball joint is that if you go over a somewhat big bump the ball joint hits the inner fender and makes a clunk noise. No big deal though.
Old 08-27-2009, 03:51 AM
P_Adams's Avatar
True, one of the more common complaints of a dropped 5th gen; that, and of course the observation of accelerated tire wear if not realigned.
I (personally) have used offset inner bushings to bring back into range a tweeked front end. (I'm a "set it and forget it" kinda guy), but for your intended use, adjustable ball joints make the most sense.
One observation:
Be very (very) careful to avoid road debris, curbs and the ever increasing pot holes. I can't see much of a bead protector on your sidewall and you stand a good chance of taking out both a tyre and a rim if you hit something inappropriate.
P
Old 08-27-2009, 04:40 AM
Gnate's Avatar
Thanks guys I think i'm gonna get a couple of
http://www.ingallseng.com/35720-3573...rm-mounts.html
and
http://www.sportcompactonly.com/part_p-104432.htm
Stonage07
Suspension & Brakes
08-11-2018 02:08 PM
JRSCEP3
Northern California (Sales)
07-01-2014 03:57 PM
jdmsir4dr
27
04-22-2010 11:23 AM
thebigone
Suspension & Brakes
06-09-2009 07:24 AM
Quick Reply: Camber, caster, toe & a dropped 1997 acura CL
