Wheel Bearing Replacement '02 Accord Coupe - Honda-Tech
Old 03-07-2007, 12:35 PM   #1
B18C_EJ8's Avatar
Default Wheel Bearing Replacement '02 Accord Coupe
Any idea if there's a DIY or How-To on replacing the front wheel bearings? I think I have one on its way out...
B18C_EJ8 is offline   Reply With Quote
Old 03-07-2007, 02:55 PM   #2
Accord2k-Hybrid's Avatar
Default Re: Wheel Bearing Replacement '02 Accord Coupe (B18C_EJ8)
I've got one in my chiltons.
You're going to need a press to get those wheel bearings out.
I removed the whole piece that holds the wheel bearings and brought them to a NAPA, they usually have a machinest of some sort, he replaced the bearings quickly, I reinstalled everything and I was done.
Accord2k-Hybrid is offline   Reply With Quote
Old 03-25-2007, 02:53 PM   #3
B18C_EJ8's Avatar
Is #2 in this diagram the wheel bearing??
Old 03-25-2007, 07:57 PM   #4
soon2bdropped's Avatar
Default Re: (B18C_EJ8)
no number 3...
soon2bdropped is offline   Reply With Quote
Old 03-25-2007, 08:14 PM   #5
B18C_EJ8's Avatar
Really? The bearing is built into the hub assembly?
As stated in my cheap-*** Haynes manual, the bearing needs to be pressed out, but # 3 definitely doesn't look like it gets pressed anywhere since it's got screwholes...
Old 03-25-2007, 09:08 PM   #6
yes your right i double check and 2 is the bearing..
Old 03-26-2007, 05:14 AM   #7
H-T Order of Merit
TouringAccord's Avatar
TouringAccord is offline   Reply With Quote
Old 03-26-2007, 07:08 AM   #8
B18C_EJ8's Avatar
Default Re: Wheel Bearing Replacement '02 Accord Coupe (TouringAccord)
Quote:
Originally Posted by TouringAccord
OUTSTANDING!!
Old 04-09-2007, 04:42 PM   #9
B18C_EJ8's Avatar
I would imagine I should replace with Honda OEM parts, correct?
99 EM1 Wheel Bearing Question. jason_SIR Honda Civic / Del Sol (1992 - 2000) 9 03-25-2014 02:49 PM
front wheel bearing ElCivic89 Honda CRX / EF Civic (1988 - 1991) 3 05-09-2011 01:05 PM
Wheel bearing roaring kevin22trac Honda Prelude 5 05-09-2008 11:00 AM
another wheel bearing question rollercosta123 Honda Accord (1990 - 2002) 2 01-10-2007 08:15 PM
Wheel Bearing Question bigslimdog Honda Civic / Del Sol (1992 - 2000) 11 08-12-2004 06:36 PM
Tags
02, 2000, 2002, 2003, accord, bearing, bearings, coupe, diy, honda, replace, replacement, replacemnt, replacing, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
