What is your tire pressure??? - Honda-Tech
Old 01-07-2010, 10:45 AM   #1
uberEFtuner's Avatar
Default What is your tire pressure???
Post your opinions and your preference for tire pressure.
I have a 93 accord LX with 15" wheels. Inside the door it says 29psi but the car came with 14" wheels. The tires look flat when at 29psi.
-I always had my 91 civic with 14" wheels at 35psi.
uberEFtuner is offline   Reply With Quote
Old 01-07-2010, 10:49 AM   #2
He knows where you live!
TheMuffinMan's Avatar
Default Re: What is your tire pressure???
Should be 32 PSI, it's written in your door
TheMuffinMan is offline   Reply With Quote
Old 01-07-2010, 11:02 AM   #3
GhostAccord's Avatar
It is stated on the tire sidewall as well. Most times I go buy the tire manufacturers recommended tire pressure. Between the two they are probably within 3-4 psi of each other.
GhostAccord is offline   Reply With Quote
Old 01-07-2010, 11:39 AM   #4
Conan's Avatar
If you have a decent name brand tire, the manufacturer may have fitment guide that has a good place to start. Or the place you purchased them from may have a fitment guide with the info for your car. The number on the sidewall is normally MAX pressure. Another old rule is take the vehicle weight and divide by 100. then add 2 psi to the heavier end. And add 2 psi if the suspension is stock.
Conan is offline   Reply With Quote
Old 01-07-2010, 12:23 PM   #5
Quote:
That's always the max tire pressure I've seen............ which is like 80 + psi
Old 01-07-2010, 12:37 PM   #6
Quote:
You are correct about the Max pressure. But the stamp on the side of my tires says 35psi Max and that is what I have always put in them. No odd wear and they were on my car for three years. Still have lots of tread too.....They never wore down the center like an over inflated tire would. guess I got lucky eh!
Old 01-07-2010, 12:57 PM   #7
02 accord's Avatar
I run 39 psi in my 02.
02 accord is offline   Reply With Quote
Old 01-07-2010, 01:47 PM   #8
alkoholikwun's Avatar
around 37psi
alkoholikwun is offline   Reply With Quote
Old 01-07-2010, 06:07 PM   #9
djkurious's Avatar
32 PSI
djkurious is offline   Reply With Quote
Old 01-07-2010, 08:45 PM   #10
nus_dogg's Avatar
35 PSI in my 16" Rota.
nus_dogg is offline   Reply With Quote
Old 01-07-2010, 09:59 PM   #11
50 psi, but i have 205/40 r 17s. I think I had like 34-36psi in my stock tires, which were 185/70 r14s i believe, which were stock size tires on my '90 lx.
Bright13 is offline   Reply With Quote
Old 01-08-2010, 02:23 AM   #12
aasaa666's Avatar
Every tire brand and model has their own max psi like everyone here is saying. The door jam recommended pressure is the minimum recommended by Honda on controlled conditions. Tire pressure changes during hot or cold, elevation, and depends on what you fill the tire with. So if you live in hot places like the desert of Nevada then Id recommend you fill it to minimum pressure and don't go over the max indicated on the tire sidewall. I live in tropical weather, when the tire heats up it rises 2-3 psi. So I put mine at 36 psi. just because it looks flat doesn't mean it is, you might get yourself hurt if the road is slippery or wet when you over inflate it. so please don't.
aasaa666 is offline   Reply With Quote
Old 01-08-2010, 10:57 AM   #13
bigsnorlax's Avatar
Quote:
correct, but also having it under inflated can cause you to hydroplane easier in wet conditions because of the increase in surface area atleast my drivers ed book said that. My tires say 35, and if yours are stock, id say thats the average. Just look into what the tires say
bigsnorlax is offline   Reply With Quote
Old 01-08-2010, 02:49 PM   #14
accord_raffi's Avatar
my tires handle more boost than my engine. wooooo
accord_raffi is offline   Reply With Quote
Old 01-08-2010, 04:49 PM   #15
fleetw00d's Avatar
The tires on all four of mine list 44 psig max. Typically run them mid to upper 30's. 40 for a long trip with a load. No abnormal pressure related wear. Keep in mind that most of the manufacturer's recommended numbers are a compromise among tire life, handling, comfort, etc. Running them on the high side, while it may be a stiffer ride (which I suspect many of us prefer) improves handling and reduces rolling resistance, which improves gas mileage.
fleetw00d is offline   Reply With Quote
Old 01-08-2010, 05:15 PM   #16
j3wman's Avatar
40 PSI on 15" Wheels
25 in front when at the strip
j3wman is offline   Reply With Quote
Old 01-08-2010, 07:42 PM   #17
WHEEELMAN's Avatar
17" rims. Falken 912 w/ 215-50 profile. 41 front/39 rear
WHEEELMAN is offline   Reply With Quote
Old 01-11-2010, 11:08 AM   #18
i have always ran between 35-37 and occasionally even 40 psi as well in my 215/45/17. I always get edges of my tires wearing off more than the middle. I know with over-inflation is supposed to cause the middle to wear more, but I have yet to see one of my tires that the middle wear more. This was always the case, even with stock suspension.
I am thinking of just running 32psi now and see if it correct the problem.
professorman is offline   Reply With Quote
Old 01-11-2010, 12:40 PM   #19
alvarado626's Avatar
I got 0 PSI one of my tires get flat this Morning When i Got to My Car This Morning My Car Was Uneven WTF
alvarado626 is offline   Reply With Quote
Old 01-24-2013, 06:34 AM   #20
I was advice by a mechanic to remove the themostat of my Honda accord Ex 2005. he said the thermostat is ment for cold regions and not for places like Nigeria with 45 dgress celcius. Should i remove it or leave it? i need advice to proceed
Chaulkie is offline   Reply With Quote
Old 01-24-2013, 06:39 AM   #21
coolkidirish's Avatar
mine is usually 34psi, but then my slicks are 15-18psi
coolkidirish is offline   Reply With Quote
Old 01-24-2013, 08:57 AM   #22
I keep the tires psig on my 95' Honda Accord at 40 and runs fine. I may have to drop the psig on the rear tires by 2-3 psig. The tire size is 185/75 R14 and Max. 44 psig. So far, the car runs fine and looking to save the most gas.
vega66lm is offline   Reply With Quote
Old 01-24-2013, 12:01 PM   #23
Quote:
How is this anyway related to tire pressure from 2 years ago?
Plus, you're in the wrong section (90-02 Accords)
Plus, you don't say why the thermostat change was recommended in the first place. If the car is running fine, don't mess with it.
Old 01-24-2013, 03:58 PM   #24
EfyourK's Avatar
32 psi alllllll day!
EfyourK is offline   Reply With Quote
Old 01-25-2013, 12:26 AM   #25
lol good luck NOT blowing your tire when you try to reach 80 psi.. I assume that's a joke
holmesnmanny is offline   Reply With Quote
Tire Pressure Different Tire Size pezzy Honda Civic / Del Sol (1992 - 2000) 8 12-29-2009 05:39 PM
another which tire post, appologies. Ammadien Wheel and Tire 6 03-20-2006 02:02 PM
tire pressure ?(track) danteisme Acura Integra 6 09-08-2005 10:32 PM
hooked up oil pressure guage...my readings...need your opinions hondaeg8 Tech / Misc 9 01-26-2004 04:37 PM
Tire Pressure? InfamousRS Acura Integra 7 02-14-2002 12:41 AM
Tags
1994, 2000, 2001, 95, 96, 99, accord, civic, cold, honda, lx, pressure, recommended, tire, tyre
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
