94 accord w/ h23 swap help
Old 01-24-2013, 05:13 PM
deltazlt's Avatar
Default 94 accord w/ h23 swap help
I just bought this accord and it has been swapped over to a h23, and whoever did it put some weird mount on the drivers side and im looking to replace it, which mount do i need? Prelude or accord?
Old 01-24-2013, 05:19 PM
PhatBoiOnDiet's Avatar
Default Re: 94 accord w/ h23 swap help
Mounts-
Rear-Front-Passenger side Accord Mounts
Drivers side Prelude Mount (will need slight grinding to fit)
make sure you get the mount from a 92-96 prelude
Old 01-24-2013, 05:23 PM
Chris_McCartney's Avatar
Prelude 92-96 engine mount on the nearside and an Accord mount on the Offside. Apparently Prelude mount needs slight trimming but. Anyway, not-so-cheap shiny mounts below...
http://hasport.com/store/index.php/m...3rgemars1v1g42
deltazlt's Avatar
Thanks so much! Also at times it doesnt want to go in gear... has new master and slave cyl, could it be the clutch going out?
Old 01-24-2013, 05:39 PM
Sounds like the shift linkage... https://honda-tech.com/forums/honda-prelude-4/shift-linkage-problem-2790234/
Old 01-24-2013, 06:51 PM
deltazlt's Avatar
hmm, all the gears are where they should be, its nothing like that, though when the clutch does actually disengage the pedal is less than a quarter inch off the floor....
Old 01-24-2013, 06:59 PM
Hmm I got no idea then sorry, this is my first Honda and only got it last week. Shift linkage was the problem in my old mk4 Golf/Rabbit and it sounded like the same symptoms. Sorry mate.
Old 01-25-2013, 09:41 AM
How's the pressure on the clutch is it soft or hard?
Old 01-25-2013, 01:58 PM
na_cd7's Avatar
check for master leak on your interior fire wall fluid would soak into the carpet and if you slave is bad squeeze the boot to see if fluid comes out if it. if you like me and dont like problems down the road replace both at the same time
Old 01-25-2013, 02:45 PM
He said he has new Mas and Slave Cyl.....
Old 01-25-2013, 02:46 PM
Maybe a bad pressure plate
pinecone
05-12-2007 07:30 PM
H23preludeSi
04-20-2004 08:17 AM
H23preludeSi
04-19-2004 04:24 PM
yellowsi99
03-15-2004 01:14 AM
Quick Reply: 94 accord w/ h23 swap help
