what wheel bolt pattern is a 92 accord? - Honda-Tech
Old 11-03-2009, 01:27 PM   #1
Default what wheel bolt pattern is a 92 accord?
Ive never messed with an accord lol!...Is it 4x100 or 4x115 or something else?
InTheLBC20 is offline   Reply With Quote
Old 11-03-2009, 05:52 PM   #2
Default Re: what wheel bolt pattern is a 92 accord?
Anyone who wants to know its 4x114.3
Old 11-03-2009, 09:22 PM   #3
cd5feezee's Avatar
its the same for the 94-97's
cd5feezee is offline   Reply With Quote
Old 11-06-2009, 03:12 PM   #4
babiboidb1's Avatar
yup unless you got a 5 lug
babiboidb1 is offline   Reply With Quote
Old 02-16-2013, 01:20 PM   #5
I have a 1992 Honda Accord LX.
It has 14 inch wheels--the bolt pattern must be 114.3 correct?
Do the 15" wheels have a 114.3 bolt pattern also?
Where can I find out which years has 15 inch wheels?
Where can I find out which years had 4 lugs or 5 lugs?
What year did they stop using a 4 bolt pattern?
What is the spacing for the 5 lug wheels?
To put it simply, where can I find out ALL the information on Honda Accord wheels?
Thank you in advance.
Triker is offline   Reply With Quote
Old 02-16-2013, 03:37 PM   #6
all accords 92-98 94-96 prelude also have bolt pattern 4x114.3 i also believe but am unsur but the ITR with 4 lug has it also.
yes the 15s come with the same bolt pattern as long as they are from other accord aluminum 6 spoke 7 spoke etc;
honda spacing for 5 lug is 5x100 so im told
google....
na_cd7 is offline   Reply With Quote
Old 02-16-2013, 03:41 PM   #7
GhostAccord's Avatar
All 90-97 Accords use the 4 x 114.3 bolt pattern. The 98+ 5 lug are also a 114.3 bolt pattern.
Here is a comprehensive lug and bolt pattern list of Honda vehicles; http://www.discountedwheelwarehouse...._Reference.cfm
GhostAccord is offline   Reply With Quote
Old 02-17-2013, 06:11 AM   #8
Also, between 98 and 02 the Accord came with 4 lugs with the 4 cyl motor, and 5 lugs with the V6, but all were 114.3 (4 1/2). Something to watch out for is that the offset of the wheel varies and a wheel with 55mm positive offset may not clear the rear suspension on a 90-97 accord.
Fitz Williams is offline   Reply With Quote
6x9 speakers in accord 94 mike001 Honda Accord (1990 - 2002) 10 05-17-2006 05:18 PM
lug pattern on 88-91 accords? Tuner Eddy Honda Accord (1990 - 2002) 1 12-01-2005 08:20 PM
4th gen accord 4x114 or 4x100? aktc167 Honda Accord (1990 - 2002) 7 02-04-2003 09:00 AM
bolt pattern 2000R Honda Accord (1990 - 2002) 2 07-28-2002 09:49 PM
accord wheels 4x100? Lo-Buck EF Honda CRX / EF Civic (1988 - 1991) 4 01-26-2002 07:08 PM
Tags
1988, 1991, 1992, 92, 93, 94, accord, bolt, crx, honda, lug, pattern, specs, v6, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
