Honda Accord 2000 EVAP Emission Control System
Old 10-17-2012, 09:14 PM
mejia.julio92's Avatar
Icon6 Honda Accord 2000 EVAP Emission Control System
I have a Honda Accord 2000 6cyl 4dr, with check engine light on, checked the code and it said the evap emission control system leak, so i was wondering if someone can give me information or pictures of what tubes/hoses are part of the evap system???
Old 10-18-2012, 10:51 AM
jdowen2's Avatar
Default Re: Honda Accord 2000 EVAP Emission Control System
What is the code?
Old 10-18-2012, 11:31 AM
jdowen2's Avatar
Could be a loose or defective gas cap!
Old 02-13-2013, 06:46 AM
dgarlotti's Avatar
Hi, I have the 01 Accord with the V6 engine. I too have had repeated engine light coming on. Each time I tighten down on the gas cap, the light clears after several engine cycles. the LAST time it happened (recently), I replace the gas cap with an OEM one,,,the CEL goes off. Yesterday, i got the CEL again..perhaps i did NOT tighten the g cap down hard enough again.
BUT - my question is,,,with a NEW g cap on there - what else could be causing this... the EGR thing, or the two 02 sensors? I need to get this fixed to i can pass my EPA vehicle test in Illinois. thx.
Old 02-16-2013, 04:36 AM
poorman212's Avatar
Originally Posted by jdowen2
What is the code?
Old 02-17-2013, 07:37 AM
dgarlotti's Avatar
Hi, I have a 1457 code. It actually cleared again two days ago (after I think I did NOT screw down the gas cap about a week ago). I am/was ready to change out the vent shut valve (first) as per what I read was 90% of the cause of this CEL. After that, it says to change to Purge Control Valve and the 2way-valve. All in all - I'll wait to see if it comes back...hard to believe that the gas cap not being on tight will cause the 1457 code; as I understand they ARE ? or ARE NOT ? dependent on each other. stay tuned,,,thx for your reply.
4est2sea
Honda CR-V & Element
08-08-2017 04:20 AM
learnonmyown
09-15-2014 05:35 PM
FunkTechNician
02-01-2011 02:31 PM
poly35
03-14-2007 06:53 AM
londonsupra
07-07-2006 05:30 PM
Quick Reply: Honda Accord 2000 EVAP Emission Control System
