what kind of tranny fluid? - Honda-Tech
Old 04-08-2008, 10:12 AM   #1
9cobra4's Avatar
Default what kind of tranny fluid?
i tried to search guys but didnt come up with a straight answer..i have a 1995 honda accord dx 4 cylinder non vtec five speed, i just need to know what kind of tranny fluid to use and how many quarts?...thanks in advance.
9cobra4 is offline   Reply With Quote
Old 04-08-2008, 11:04 AM   #2
Hobbs94's Avatar
Default Re: what kind of tranny fluid? (9cobra4)
i would only use honda trans fluid. just og to your local dealer and ask for it in the parts department. i can't remeber how many quarts it holds though
Hobbs94 is offline   Reply With Quote
Old 04-08-2008, 11:53 AM   #3
AR-cb7's Avatar
yeep go honda but yea u need 4 quarts
AR-cb7 is offline   Reply With Quote
Old 04-08-2008, 01:45 PM   #4
Honda ATF or MTF only depending upon auto or manual
YeuEmMaiMai is offline   Reply With Quote
Old 04-08-2008, 02:09 PM   #5
Default Re: (YeuEmMaiMai)
I think he says that he has a 5spd. You use Honda MTF. You can use regular 10W30 Motor oil as well. I used that for a while, but I changed to Honda MTF when I changed my clutch.
professorman is offline   Reply With Quote
Old 04-08-2008, 03:16 PM   #6
extralargenog's Avatar
Default Re: (professorman)
Friction modified Syncromesh... Only the GM ****, NOT ANY other.
extralargenog is offline   Reply With Quote
Old 04-08-2008, 08:20 PM   #7
AR-cb7's Avatar
Default Re: (extralargenog)
go wit honda atf cuz it will act up after a while if u use sum 10w bull ****
Old 04-09-2008, 05:14 AM   #8
H-T Order of Merit
TouringAccord's Avatar
Default Re: (AR-cb7)
what are you talking about???
4 quarts?? try only 2 qts.
ATF in a manual transmission, no... yes you can use 10w-30 in a manaul transmission though I prefer to use Honda MTF. Also, like stated above, some use GM syncromesh. I believe Honda also came out with their own version of syncromesh which you could use as well.
TouringAccord is offline   Reply With Quote
Old 04-09-2008, 07:59 AM   #9
Default Re: (TouringAccord)
Ya know what else I had REALLY good luck with was straight 10-30 Royal purple..... Shifted smooth as silk
Old 04-09-2008, 08:25 AM   #10
Heat's Avatar
Buy Honda manual tranmission fluid, you can get it from your local dealer for $5.90 per quart. You either need two, or just over two, quarts - just buy three and keep the receipt in case you don't need to tap into the third bottle.
You can also buy it online for around $4.50 per quart plus shipping if you don't have a honda dealer nearby. One site would be http://www.handa-accessories.com (on that site you can't select a '95 Camry - just choose a '98 and you'll see the manual transmission fluid under maintenance items).
Heat is offline   Reply With Quote
Old 04-09-2008, 10:15 AM   #11
flight50's Avatar
Default Re: what kind of tranny fluid? (Heat)
back before honda came out with tranny fluid they did use motor oil. and at the least use MTF. all though most dealers have gone with the newer version that has the syncromesh like additive. not all are carrying the newer version. it took mine like a year or so to carry it vs one in San Antonio or Cali, they had it like a year before that. its the one in the green bottle. i don't remember the part number though. it has solved a lot of peoples grinding problems and getting into gear problems.
flight50 is offline   Reply With Quote
Old 04-09-2008, 11:16 AM   #12
9cobra4's Avatar
thanks alot for the replies.
Old 04-09-2008, 12:14 PM   #13
Derek128's Avatar
Default Re: (9cobra4)
some honda dealer in us got the Honda MTF II
its semi syn & Made in Japan
Derek128 is offline   Reply With Quote
Old 04-09-2008, 01:19 PM   #14
Derek128's Avatar
Default Re: (Derek128)
btw here is the Honda MTF III (i don't think any dealer in US have them yet)
I found these pics from egay
the Item number is 130206221989
Old 04-09-2008, 01:21 PM   #15
dleccord's Avatar
so that's the semi synch?
dleccord is offline   Reply With Quote
Old 04-09-2008, 01:27 PM   #16
Derek128's Avatar
Default Re: (dleccord)
I know the MTF II is semi synch
but not sure about the MTF III
Old 04-11-2008, 12:05 AM   #17
oo_phuong's Avatar
Default Re: what kind of tranny fluid? (flight50)
Quote:
would using castrol full syntec 10w30 motor oil be good?? would it lead to any grindin or gettin into gear probs??? im kinda goin through the same thing
oo_phuong is offline   Reply With Quote
Old 04-11-2008, 12:46 AM   #18
TOO MUCH TORQUE's Avatar
Default Re: what kind of tranny fluid? (oo_phuong)
Quote:
dont use motor oil. why would you use it if honda has made dedicated tranny fluid? come on logic folks.
TOO MUCH TORQUE is offline   Reply With Quote
Old 04-11-2008, 12:54 AM   #19
dleccord's Avatar
yeah but maybe they didnt think we would find a better substance?
Old 04-11-2008, 02:20 AM   #20
oo_phuong's Avatar
Default Re: what kind of tranny fluid? (TOO MUCH TORQUE)
Quote:
well not everyone know bout that, if you go to autozone, they'll say 10w30 motor oil for mt, well atleast for me thats what they said
Old 04-11-2008, 06:53 AM   #21
H-T Order of Merit
logic tells me to look in the service manual and see what they list. So do that and let me know...
Old 04-11-2008, 07:06 AM   #22
FInd a tall building, and leap from it in a single bound....
Old 04-11-2008, 11:33 AM   #23
Default Re: what kind of tranny fluid? (extralargenog)
Quote:
if you want to use motor oil for your tranny, be my guess, im not stopping you
Quote:
the manual says to use honda mtf or use motor oil if absolutely necessary, but change it out asap.
Old 04-11-2008, 12:19 PM   #24
H-T Order of Merit
what manual are you looking at? Haynes/Chiltons or Helm/factory? Because I don't see anything about if absolute necessary or changing out asap.
Old 04-11-2008, 12:24 PM   #25
I have....
Royal purple 10-30... Making over 600WHP... No issues (with the oil or failure due to it).
OEM Honda Coolant and Manual tranny fluid question. newyawkballa Honda Civic (2001 - 2005) 2 02-14-2012 02:57 PM
tranny fluid b20c Transmission & Drivetrain 0 01-15-2009 07:51 PM
What grade and what kind of fluid to put in b16a1 tranny B16Jacques Tech / Misc 8 09-18-2006 10:18 AM
tranny fluid princeallure Acura Integra Type-R 8 06-09-2004 11:12 AM
Clutch Replacement jdm4life Tech / Misc 3 11-16-2002 01:39 PM
Tags
1992, 1996, 92, 98, accord, accore, change, fluid, gk, honda, kind, manual, mtfiii, tranny, vtec
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
