what kind of oil in a 1998 v6 accord? - Honda-Tech
Old 07-08-2005, 02:31 PM   #1
question's Avatar
Default what kind of oil in a 1998 v6 accord?
Just got an a 1998 v6 accord with 180,000 miles on it. What kind of oil should I use?
And how many quarts??????
Modified by question at 3:32 PM 7/8/2005
question is offline   Reply With Quote
Old 07-08-2005, 03:21 PM   #2
13lue's Avatar
Default Re: what kind of oil in a 1998 v6 accord? (question)
Mobil 1, 5 quarts
13lue is offline   Reply With Quote
Old 07-08-2005, 07:48 PM   #3
MAFA's Avatar
Default Re: what kind of oil in a 1998 v6 accord? (13lue)
I don't recommend Mobil 1 on a car with 180,000 miles on it unless you've always been using synthetic. If you've used dino oil for all those miles, Castrol GTX or Valvoline will do. Synthetic will leak if you put it on a high mileage, dino-fed, engine.
MAFA is offline   Reply With Quote
Old 07-08-2005, 07:54 PM   #4
Chiovnidca's Avatar
5w20
Chiovnidca is offline   Reply With Quote
Old 07-09-2005, 10:29 PM   #5
allenshaw's Avatar
honda specifies 5w30
allenshaw is offline   Reply With Quote
Old 07-10-2005, 06:50 AM   #6
Chiovnidca's Avatar
Default Re: what kind of oil in a 1998 v6 accord? (allenshaw)
Quote:
They changed their recommendation to 5w20 several years ago.
Old 07-10-2005, 07:23 AM   #7
C_H_A_D's Avatar
Default Re: what kind of oil in a 1998 v6 accord? (Chiovnidca)
does synthetic burn easier? My brothers corolla is burning oil he has synthetic ( Mobil 1) the preveous owner used regular oil. He says he never had a problem with it burning oil. I told my brother to switch back.
C_H_A_D is offline   Reply With Quote
Old 07-20-2005, 02:04 PM   #8
13lue's Avatar
Default Re: what kind of oil in a 1998 v6 accord? (StockAccord)
Well, Mobil1 doesnt only make Synthetic, they make regular oil too. You should also go with whatever the previous owner used. Unless its low mileage car and you flush the engine, then use Synthetic oil it'll be alright (correct me if I'm wrong) .
Old 07-21-2005, 12:59 AM   #9
1998hondaaccord's Avatar
Depends on your climate go to Bobistheoilguy.com for infomration about that stuff.
1998hondaaccord is offline   Reply With Quote
Possibly buying an 8th gen Accord Coupe soon. Oil consumption problems question. discodisco Honda Accord & Crosstour (2003 - Current) 0 09-05-2016 02:26 PM
Engine j30a1 block swap 2002 to a 1998 Accord V6 Deaner50 Honda Accord (1990 - 2002) 0 07-25-2016 02:14 PM
replacing 1998 accord V6 rear engine mounts... pattisapyro Honda Accord (1990 - 2002) 0 05-25-2009 04:49 PM
1998 accord v6 hot or cold... question thambi23 Honda Accord (1990 - 2002) 3 01-27-2008 02:07 AM
Engine swap - Chassis model CF9, gyanend Honda Accord (1990 - 2002) 8 08-27-2007 07:31 PM
Tags
1998, 2000, 2003, 98, 99, accord, honda, kind, oil, put, quart, quarts, recommended, take, v6
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
