What engine will fit an 94-97 Accord?
Old 01-26-2003, 09:49 AM
nEoMuGen's Avatar
Default What engine will fit an 94-97 Accord?
My friend is looking for a used Accord then swap out the engine.
Our first choice would be H22A, but will the 98+ ones fit in a 94-97 Accord?
and is it more difficult and less reliable than the older H22A?
Also, will the stock Accord Transmission handle the engine well or do I need to change the tranny as well?
Last but not least, will there be any LSD options on the H22A?
Old 01-26-2003, 10:30 AM
JailBa8's Avatar
Default Re: What engine will fit an 94-97 Accord? (nEoMuGen)
Damn with that many post u would think that a search would've been done. It has to be the most talk about subject for accords but anyway. Any year H22a will fit in the 94-97 accord. Just make sure that the engine u're putting is the same year or newer than the car u're putting it into. Well as for tranny u can use the accord or the prelude but i mean if u're swapping the engine why not just put the prelude tranny while u're at it. There's an LSD option for the H22a quaife baby. Anyway all your questions would be better answered in the hybrid section or actually the search button can do wonders too aight.
Old 01-26-2003, 11:00 AM
nEoMuGen's Avatar
Default Re: What engine will fit an 94-97 Accord? (JailBa8)
I did to a search, but none were specifically aimed at which H22A
[Modified by nEoMuGen, 3:00 PM 1/26/2003]
Old 01-26-2003, 11:11 AM
iam7head's Avatar
boost the f22
btw your friend's accord is ex? vtec?
Old 01-26-2003, 11:19 AM
nEoMuGen's Avatar
Default Re: What engine will fit an 94-97 Accord? (iam7head)
boost the f22
Still in the market for one...budget $7000 for the car and another $7000 for the whatnots. You suggesting boosting the EX Vtec?
Basically, I am pulling him away from street drag into Autox and Circuit racing. So we might go the route of NA with nice suspension setups. Power add-on will be only I/H/E for now, rest on brake/suspenion/tires.
[Modified by nEoMuGen, 3:20 PM 1/26/2003]
Old 01-26-2003, 12:02 PM
twkdCD595's Avatar
how could you not find a thread refering to a h22, that is the subject like at least once every other day.
keep your f22 and boost. for all motor buy a h22.
Old 01-26-2003, 01:15 PM
nEoMuGen's Avatar
Default Re: What engine will fit an 94-97 Accord? (twkdCD595)
There are H22 all over indeed. But I need to know "which" H22.
There is the 190hps and the 220 JDM ones. I need to know their differences.
Again, no boosting...NA only. So, JDM H22A 5th Gen Prelude one would be my best choice? Is it really at 220hp at the crank?
[Modified by nEoMuGen, 5:16 PM 1/26/2003]
Old 01-26-2003, 07:23 PM
paul9luap's Avatar
If you're not going to boost, i wouldn't recommend the accord tranny, eventhough it will fit fine with the prelude. the shorter gears of the preludes will be better for all motor.
also, what year accord is it, because 97+ (maybe 96, i don't know...) Accords are OBDII.
[Modified by paul9luap, 11:26 PM 1/26/2003]
Old 01-27-2003, 04:56 PM
jweller's Avatar
If your friend is going to auto-x or track the car, he should very seriously look at what class he will be in BEFORE he swaps the motor. most likely the H22 swap will put him in with the big boys, short on both car and seat time.
just a thought...
Old 01-28-2003, 12:17 PM
nEoMuGen's Avatar
Default Re: What engine will fit an 94-97 Accord? (jweller)
In that case, I'll look specifically for a OBDII Accord, although there are some modified OBD I harness that can yield some power....
Anyway, an engine swap nor FI will definetly be in Street Modified...but he's not trying to be competitive but just to have fun with it.
Old 02-09-2013, 05:47 PM
94accord-ex's Avatar
Will a 93 accord engine fit into a 94 accord
Old 02-09-2013, 06:41 PM
GhostAccord's Avatar
Yes
Old 02-12-2013, 04:59 PM
Will there be any problem wit the harness mounts or anything else I'm just starting and learning
Old 02-12-2013, 05:07 PM
I'm pretty sure the wiring won't be much of an issue. You will need the 93 exhaust manifold and down pipe. Also the complete 93 intake manifold and throttle body.
Wiring really depends on the type of coil setup you have. Whether or not they are both the same, ie internal or external coil.
Old 02-12-2013, 06:41 PM
Ok thanks a lot
Old 02-12-2013, 07:57 PM
NZXTInerTia's Avatar
You bumped a 10 year old thread for this? Yes it it will work.
Old 05-24-2023, 08:11 PM
Mydadhadahonda's Avatar
Well well well
another 10 years and another enthusiastic person trying to bring something back from the dead
currently have a 97 ex-r which I’m guessing is made in Canada from what I’m reading
trying to decide what to work on first
it has 187k and definitely rusted under so I’m guessing fuel and brake lines first then maybe a pump to accommodate what I need to do what I want it to do
any recommendations on rear axles?
Swapping trannis to accommodate?
currently I believe I have a f22 motor but I’m going to check the VIN when I get it
I read the thread and head of boosting it but definitely going to look for a lower mileage motor to drop in maybe something in th k from what I’m hearing
just don’t know what a k went into to start looking
eventually I want to make it a tuner I can drive to work everyday and maybe hit some acceleration while going 5th gear already
Perhaps tearing down this one and swapping cams and pistons if the tubing is good?
Thank you in advance
Old 11-10-2023, 12:09 PM
Mopargurl's Avatar
Originally Posted by iam7head
boost the f22
if you boost the f series there has to be a new bottom end replacement with new rods, pistons, etc and thats easier to build the h22 while its still out than to pull your current motor and build it when adding g a turbo. Sometimes its all about whats easier and quicker.
crossmiles8
11-28-2012 08:46 PM
bakerskater11
09-20-2009 09:44 AM
D21X
09-15-2003 09:05 AM
Quick Reply: What engine will fit an 94-97 Accord?
