Upper Ball Joint Question...
Old 02-03-2002, 10:35 PM
briq4's Avatar
Default Upper Ball Joint Question...
I have a 1993 Accord EX and the upper ball joint boot has a hole in it, just wondering if it's possible to replace the boot without replacing the ball joint (especially since the ball joint is integral with the control arm)? THanks in advance!
Old 02-04-2002, 03:52 AM
New User
urbanlegend21's Avatar
Default Re: Upper Ball Joint Question... (schlit)
duct tape works great
Old 02-04-2002, 04:51 AM
Accord94DX's Avatar
Default Re: Upper Ball Joint Question... (urbanlegend21)
Old 02-04-2002, 07:31 AM
briq4's Avatar
Default Re: Upper Ball Joint Question... (briq4)
THanks! How'd ya get the grease back in tho?
Old 02-04-2002, 07:32 AM
New User
just buy a tube of grease from a auot parts store and pack it in there
Old 02-04-2002, 11:43 AM
FastechAccord's Avatar
You can buy the rubber boot, but not the ball joint itself. If you buy the rubber boot to replace the old one, remember to pack it in grease b4 you reinstall it.
Old 02-05-2002, 08:46 AM
briq4's Avatar
Default Re: Upper Ball Joint Question... (EvoAccord)
OK say I buy the boot, how do you get the boot on without separating the ball joint? THanks!
Old 01-01-2007, 11:26 PM
Jmumblez2001's Avatar
Default Re: Upper Ball Joint Question... (briq4)/boot replacement
Found this post in the archives and i had to bring it up. NEEd to replace my upper ball joint boot i have the boot and the circle clip, my ? is can all this be done by hand, or do i need a special tool to install the circle clip. The car is a 1994 honda accord.
Also how necessary is the cotter pin cause at the moment i do not have one in my upper ball joint because the **** HEAD MECHANIC broke it in the stud.
Old 01-01-2007, 11:30 PM
YeuEmMaiMai's Avatar
Default Re: Upper Ball Joint Question... (briq4)/boot replacement (Jmumblez2001)
support the suspension, remove balljoint, replace boot after packing full of grease, reinstall ball joint
Old 01-02-2007, 06:45 AM
hondadude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by briq4 &raquo;</TD></TR><TR><TD CLASS="quote">OK say I buy the boot, how do you get the boot on without separating the ball joint? THanks!</TD></TR></TABLE>
You do need to get it loose from the upper knuckle arm;
Raise and support the car, remove the tire, remove the cotter pin back the nut off the ball joint stud,don't take it all the way off yet. Now grab up your handy dandy 2 pound hammer. wail away and smack right where the ball joint stud passes thru the knuckle part of the joint, quit swinging the hammer like a girl and hit it!! LOL
All of a sudden the joint will pop loose then you remove the nut that you left on in case you missed with the hammer. Remove and replace the boot, and reassemble.
Old 01-04-2007, 01:27 AM
TOP END MS's Avatar
Sounded good until you go to the hammer. what you should do is buy a ball joint seperator. For the top ball joint it will look like a fork. You slip that around the ball joint, then wail on the end of that with a solid metal hammer until it pops loose. Honda manual shows a special ball joint boot clip installer .. but basically it just looks like a cone.. and you slide the clip over that and into possition. Im pretty sure you wont need it tho, but might give you a little bit more of a hard time .. but youll get it..
retriever99
01-08-2020 07:12 AM
Hala
08-08-2009 10:31 PM
tungkung
Honda Civic (2001 - 2005)
07-09-2008 08:06 AM
MisterB
08-03-2004 05:59 AM
Rywire
03-11-2004 12:21 PM
Quick Reply: Upper Ball Joint Question...
