f20a sohc
Old 02-16-2007, 06:58 PM
sirtef9's Avatar
Default f20a sohc
thats not a stock motor for a 90 accord lx is it? if so any idea whats it from?
Old 02-16-2007, 07:06 PM
bamjones4444's Avatar
Default Re: f20a sohc (sirtef9)
I KNOW THAT A F20A1 IS A DOHC MOTOR FOR A 90-93 ACCORD Si WITH 155HP SO THE F20A MAYBE THE REGULAR SOHC MOTOR FOR THAT YEAR, BUT I HAVE A 92 ACCORD WITH A F22 2.2 IN IT FROM FACTORY
Old 02-16-2007, 07:45 PM
sirtef9's Avatar
Default Re: f20a sohc (bamjones4444)
i know they got the f22a1 stock, but just curious where this f20 is from, to bad its not a f20c lol
Old 02-16-2007, 11:17 PM
ate my pixel
Twixle's Avatar
Come on dude, it's not that hard to do an online search, and that would be faster than waiting for a response. Here you are:
[edit] F20A
This engine series was used in the 1989-1992 and 1993-1996 Honda Accords in Japan. The DOHC F20A was also derived from this engine (see below).
Specifications
Bore × Stroke: 85.0 × 88.0 mm
Displacement: 1997 cc
Valve Configuration: SOHC, 16 valves
Max output : 135 PS @ 5400 rpm (PGM-Fi), 110 PS @ 6000 rpm (PGM-carb)
Max torque : 18.5 kgm @ 4300 rpm (PGM-Fi), 16.1 kgm @ 3800 rpm (PGM-carb)
Fuel consumption (Japan Combined Cycle) : 9.6 km/l (PGM-Fi), 9.8 km/l (PGM-carb)
This engine also spawned many variants, according to market, but the specs remain largely similar
[edit] F20B
This engine series was used in the CF4, CF5, CF9, CL3 Honda Accord from 1998-2002. Also had a DOHC derivative (see below)
Specifications
Configuration Valve: SOHC, 16 valves, VTEC
Compression ratio: 11.0:1
Max power: 148 PS (109 kW) @ 6000 rpm (4WD), 150 PS (110 kW) @ 6000 rpm
Max torque: 183 Nm @ 5000 rpm (4WD), 186 Nm @ 5000 rpm
[edit] F20Z
This engine series is similar to the F20A above, used in the Honda Accord in Asia and Europe.
Specifications
slayerfromhell212
12-29-2006 10:41 PM
Rishiras
03-02-2006 02:50 PM
kuckimonster2
02-22-2005 07:37 PM
d15civ
11-19-2004 06:11 PM
jwogen1
03-16-2004 02:45 PM
Quick Reply: f20a sohc
