Two horns on the 97 Honda Accord - Honda-Tech
Old 01-04-2011, 10:24 AM   #1
Default Two horns on the 97 Honda Accord
I'm looking for the location of the two horns on the 97 Honda Accord. I found one in the engine bay on the right side as you stand in front of the engine. Where is the other one?
Jetjock is offline   Reply With Quote
Old 01-04-2011, 10:30 AM   #2
He knows where you live!
TheMuffinMan's Avatar
Default Re: Two horns on the 97 Honda Accord
They should both be behind the lower grill/turn signal........ I don't think there is one in the engine bay at all.
TheMuffinMan is offline   Reply With Quote
Old 01-04-2011, 10:36 AM   #3
they should both be behind the front bumper rebar. you have to remove the grille, and you will see them there.
sgraham01 is offline   Reply With Quote
Old 01-04-2011, 12:37 PM   #4
I found one horn on the frame rail and disconnected it. There wasn't another one near it. The horn sounds like it is on the other side but unable to find it.
Old 01-04-2011, 12:50 PM   #5
They are both in the front
Old 01-04-2011, 01:10 PM   #6
GhostAccord's Avatar
The two stock horns are located in the center between the rad and the bumper on the 5th gens (96-97 for sure). The two rusty saucer shaped things circled below are the horns in there factory (1996-97) locations.
GhostAccord is offline   Reply With Quote
Old 01-04-2011, 01:48 PM   #7
Unfortunately, that's not where I found them. Here's a pic of the two that I have found so far. One of them was behind the front grill and the other was on the driver side frame rail. However, there is third one that I am trying to figure out where it is. I tried to put some pics here but couldn't figure it out. This is similiar to another forum but the pics post is different here. Ah, I figured it out. I can't post attachments. Bummer!
Anyway, I have found two horns so far and looking for the third. I still have a car horn going off.
Old 01-04-2011, 02:29 PM   #8
somebody must have added that horn at some point.
Old 01-04-2011, 02:51 PM   #9
If you have an OEM alarm that may be the factory siren location.
Old 01-04-2011, 03:16 PM   #10
So what I gather is that there were only two horns installed normally and the third one is the car alarm which would make sense. However, I have no information about the car itself. No owners manual or service manual is available with the car. I'm flying blind here. The Honda dealer doesn't have any information about this type of car which is kinda strange and I don't know what this car has installed. I'm guessing factory-installed alarm but the reset that I have been told doesn't work. I'm trying to disconnect the horn so that I can research out the car alarm. I've got babies on my street and I can't have the horn going off. I've disconnected two horns and looking for the third one. Where would they have put it? It's too loud to stand by for any length of time.
Old 01-04-2011, 06:41 PM   #11
Balwin's Avatar
Quote:
Nope thats where mine are too.
It seems like they changed the location for the 96/97
Balwin is offline   Reply With Quote
Old 01-04-2011, 07:48 PM   #12
Possibly in the fender well, I found an old random alarm siren in my car there.
Old 01-04-2011, 11:29 PM   #13
Balwin's Avatar
lmao! gotta love used cars.
In my parts car, there was a light switch panel (brushed metal type intended for a house) on the under part of the dash under the steering wheel with rocker switches that did God knows what..
Old 01-05-2011, 09:38 AM   #14
I've been thinking about it and realized that the car horn that I am hearing is the alarm horn and not the normal car horns all of this time. I think that it is in the right front fender well but when I opned it up, couldn't see anything in there but wires. Could they actually put it in the dash? I looked all around the engine bay but can't see anything. It's definitely on the right side of the car when it is blowing.
Old 01-05-2011, 10:42 AM   #15
Could be on the right side of the car under the battery tray, or towards the back of the firewall by the charcoal canister.
If it is the alarm then it was purposefully hidden.
Old 01-05-2011, 11:35 AM   #16
Thank you. That would make sense.
Old 01-05-2011, 01:15 PM   #17
Looked under the battery tray and found nothing. Not sure what you mean by charcoal canister location. In Vettes, they put the vapor canister in the back end of the car. There is a long black canister by the firewall. Making an assumption and assume that is the charcoal canister. Looked around it and saw nothing. Will keep looking around the right front of the car.
Old 01-05-2011, 01:23 PM   #18
Other location would be right behind the turn signal. Personally I'd remove the front bumper since it is not too difficult and I'd see if I could find any aftermarket wiring. Unless they cut open stock stuff and slipped it in you should be able to distinguish between '97 Honda wiring and whatever brand alarm wiring.
Old 01-05-2011, 04:16 PM   #19
Thanks. The real problem is that the car alarm system won't reset. I don't have any remotes and the door key reset that the Honda service advisor told me about and several mechanics confirmed doesn't work either.
Old 10-19-2014, 05:51 PM   #20
@jetjock Did you ever find the hidden alarm horn? Or, does anyone know where the hidden alarm horn is located. From what I can tell, if you are facing the car the hidden alarm sounds like it's somewhere on the right side of the car. Thanks!
sflores1230 is offline   Reply With Quote
Possible Horn Problem. 98 6th gen accord. Horn relay? b18crx Tech / Misc 0 10-05-2011 05:43 PM
Horn Failing questionquestio Honda Civic (2006 - 2015) 3 10-11-2010 09:14 PM
Changing the horn on 1995 Honda Accord EX coupe raffydogg Honda Accord (1990 - 2002) 1 03-03-2008 09:55 PM
Can the Accord Horn Unit fit the Civic 2006/2007? Modulo_Black Honda Civic (2006 - 2015) 6 01-18-2007 10:11 AM
horn replacement? Comtechgsr2000s Acura Integra 14 02-11-2002 09:15 AM
Tags
04, 1994, 1996, 2002, 94, 97, accord, alarm, honda, hord, horn, horns, located, location, turn, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
