OVERHEATING AND FAN PROBLEMS
i have a b16 swap in my four door..everything was running fine befor i broke the car down and replaced all of the bushings in the front..
Problem #1: when idleing fan does not come on automatically
Solution: tested fan=fan works, hot wired fan to switch, swapped all sensors and thermostat..
Problem #2: when driving temp is normal but when stopped temp rises.
Solution: ?????
I also noticed that when i took out the thermostat that was in the housing it is made different and just for s&g i tested it in a boiling put of water and it worked..
a friend said that my water pump might be going bad....
Solution: ?????
Re: OVERHEATING AND FAN PROBLEMS
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/ try posting in this place.
NOTUNINGNONADA
07-18-2010 06:28 AM
tianporn
07-29-2005 11:44 PM
