turns over but wont start
Old 08-02-2011, 12:03 PM
logeywartooth's Avatar
Default turns over but wont start
the car is a 95 accord lx manual transmission with a 4 cylinder.
alternator and starter work, have spark in all the plugs, getting fuel as far as the fuel rail not sure about injectors because i dont know how to check them. cleaned the distributor points and throttle body. air filter is clean. battery isnt too old and holds charge. all fuses and relays are good.
when i try to start it it will turn over but nothing happens and it will not jump start or push start.
dont know anyone who has an OBD 1 fault code reader.
Old 08-03-2011, 01:07 PM
Default Re: turns over but wont start
Bump.
Old 08-05-2011, 03:00 PM
poorman212's Avatar
Turn the key to on....does the CEL come on and go off, when t goes off you should hear the main relay click.
Check for spark at the plug?
Is the cam turning? You can pull the upper cover, or dist cap and make sure the cam is turning.
A few to start with.
Old 08-05-2011, 07:55 PM
clempot911's Avatar
A quick test to weed out whether it's fuel or spark is to buy a can of starter fluid, spray a 1 sec. blast into the air cleaner snorkel, try to start it.
If it starts then dies, problem is fuel.
If it doesn't start, problem is spark.
Old 08-06-2011, 11:34 AM
when i turn it to accessory the CEL turns on then off and i can hear it click.
forgot to mention it but i did spray a bit of wd40 into the throttle body and each of the spark plugs and it didnt make any difference.
ill try to see if i can upload a video of me trying to start it up.
Old 08-08-2011, 06:54 PM
heres the first video, its kind of loud.
http://www.youtube.com/watch?v=glWc51mfWq0
there was a bad smell inside while i was cranking it and a friends said he smelled exhaust under the hood.
http://www.youtube.com/watch?v=KMFLc-ExBeY
different angle so you can see the engine hopping around.
Old 08-08-2011, 11:22 PM
Peeonu25's Avatar
videos dont help at all. you need to figure out if its fuel or spark. you said you have spark. pull out a plug and see if its wet or do what theyve all said. starter fluid etc.
if its none of the above, then youre timing is off, or your plug wires are crossed. it helps to know how to fix a car before you start to fix it.
and if its not that you have no compression and ill buy your shell for cheap grade a USD AA+ legal tender.
Old 08-09-2011, 03:43 PM
problem solved.
seems the the guy who was helping with it mixed up the spark plug wires on the distributor cap, switched them around and it started right up.
thanks for the advice
Old 08-09-2011, 07:30 PM
novakane2778's Avatar
good answer.
Old 08-10-2011, 06:20 PM
poorman212's Avatar
problem solved.
or give the whole story up front...."I just did X (tune up, adjust valves, ect) and now"........
Old 11-30-2014, 05:44 PM
RobertE64's Avatar
Try replacing the ignition module right under the distributor I worked on mine for 5 days and replaced the fuel pump, main relay,and throttle sensor and those were all still good it turned out to be the ignition module under the distributor it runs greatnow
Old 09-04-2016, 02:08 AM
bobbigmac's Avatar
I don't know who posted the reply about 2002 civic and security light and KEYS . That was the fix for my nieghbors car . 2 keys security code in one would not start and other would . thank You these folks need a break , you gave it to them, Bobbigmac.
Candzi
12-06-2008 11:49 AM
jdmcivicsi522
05-30-2006 10:58 PM
civic efb16
08-08-2005 09:00 PM
rvanders37
08-03-2005 10:51 AM
same ol' civic
06-05-2005 07:29 AM
Quick Reply: turns over but wont start
