sway bar question......
i have a 95 accord....i have a clunking sound thats coming from the driver side every time i turn to the left...it clunks once and that it...i know its not the axle but wut i did notice is that my sway bar bushings are worn pretty bad....driver side worse than passenger side... i also notice my rack and pinion boot is f*cked up too...could either one be the problem....i dont want to start messing wit it if its not going to fix it....thanks for your time....
Re: sway bar question...... (badasswelder)
My sway bar bushing are bad and so is the boot but it doesnt make noise. Why dont you check your upper control arm ball joint. Thats what happened to me when my ball joint is about to give up.
