Turbo F22 build H22 rods 4g63 pistons low compression
Old 04-04-2010, 05:05 PM
  #251
ashb82's Avatar
Default Re: Turbo F22 build H22 rods 4g63 pistons low compression
I changed my oil today i found some shavings in my oil they where copper and the size of a period on your key board. I drained the oil threw a white t-shirt. I only found 5 of the flakes is this ok. the copper color is what scared me i have seen oil with a spun bearing it had millions of copper flakes.
ashb82 is offline
Old 04-05-2010, 02:14 PM
  #252
ashb82's Avatar
I got problems i cut my oil filter open. I have a bearing problem i think. I checked everything 10X guess i missed something. Going to pull the oil pan a check the bearings. Oh yes the fun.
ashb82 is offline
Old 04-05-2010, 07:04 PM
  #253
ashb82's Avatar
My oil pump blew out
ashb82 is offline
Old 04-05-2010, 07:12 PM
  #254
Andryzzle's Avatar
that sucks, hopefully nothing is too damaged
Andryzzle is offline
Old 04-06-2010, 03:51 AM
  #255
something different
redzcstandardhatch's Avatar
what crank pulley are you running? these engines NEED good dampning, like, at least a stock pulley. i would run an ATI or Fluidampr if you are having problems.
i'd put money on you hurt your main bearings (not rods, like an under-oiling situation). happened to me 3 times. got a fluidampr, and no problems anymore.
good luck man
redzcstandardhatch is offline
Old 04-06-2010, 03:52 AM
  #256
something different
BTW, lemme know if you need a crank, i picked up a couple of free f22s recently.
Old 04-06-2010, 05:33 AM
  #257
ashb82's Avatar
If i got alot of damage i am going to put a stock bottom end on it for a while
ashb82 is offline
Old 04-06-2010, 06:05 AM
  #258
something different
what pulley did you have on it?
Old 04-06-2010, 06:47 AM
  #259
ashb82's Avatar
stock but it has a wobble in it
ashb82 is offline
Old 04-06-2010, 03:04 PM
  #260
ashb82's Avatar
I blew out number 3 main bearing. It did not spin just warn down wtf happen
ashb82 is offline
Old 04-06-2010, 04:18 PM
  #261
d112crzy's Avatar
possibly ****ed crank.
d112crzy is offline
Old 04-06-2010, 04:51 PM
  #262
ashb82's Avatar
Are you saying from the start or are you saying after the bearing failure. After the bearing failure it needs a new crank. i got a f22b1 that has 60K on it i am pulling it apart this week and throwing in the piston n rods. The f22b1 i know ran flawless when i took it out i could not blow it. I am also ordering a fluidampr
ashb82 is offline
Old 04-07-2010, 11:42 AM
  #263
jdg1986's Avatar
It seems as if your having nothing but bad luck.Keep going,It will defenetly be worth all the trouble.I really appreciate you writing a thread on this build,I find it to very informative.Good luck with the build.
jdg1986 is offline
Old 04-07-2010, 12:49 PM
  #264
ashb82's Avatar
i figured out the Problem. My engine block was warped, the main journals needed to be line bored. I noticed when i decked the block the sleeves looked like they where shifted. then i honed the cylinders true. i thought that would make the block true. i never thought to check the straightness of the mains since the bearing clearances where good.what i did to check this lay a straight edge across the radius of the mains just as a crank would lay in the mains. i then checked to see if you could rock the straight edge and used a .001 filler gauge to check the gap from the straight edge to the main journal radius. also the straight edge is 1" wide
ashb82 is offline
Old 04-07-2010, 02:16 PM
  #265
something different
glad you figured it out!
i never build an engine that isnt perfect before disasembly anymore (bearing wise)...too many variables and what-if's.
at least it'll be a relatively cheap fix.
Old 04-07-2010, 02:39 PM
  #266
extralargenog's Avatar
Ha, so I was right it was that garbage UR pulley you had huh??? A bunch of morons on CB7tuner were arguing with me that those piles of **** are the hottest thing since Tapitio...
Retards. How you been man
ASH:
SOrry to hear, fixerman.
Ericks is running like a raped ape still...
extralargenog is offline
Old 04-07-2010, 03:40 PM
  #267
ashb82's Avatar
i will be junking the block and crank. I got a good running f22b1 i will be using. what does it take to put a f22a head on f22b1 block
ashb82 is offline
Old 04-07-2010, 06:04 PM
  #268
something different
absolutely bolts right on.
make sure you dont need to add a oil-port-thinger (behind the middle rear head stud)...make sure its the same as the block you take the head off. the f22a1 head needs a restrictor in the block..and i think ALL f series do,but cant remember).
i had an a1 head on a b2 block a while back...and i think i bolted it right on...cant remember anything special.
Old 04-07-2010, 06:05 PM
  #269
something different
anything less than a MINT stock pulley is NOW STUPID in my book! got a custom-offset Fluidampr, and NO MORE PROBLEM EVER...
Old 04-08-2010, 02:26 PM
  #270
dbsharp's Avatar
If you didn't have bad luck you'd have none! lol.
Off topic.... I wound up just buying a rod bolt stretch gauge. I was going to use your idea about making one. I was going to use the bore gauge anvil and a dial gauge I have and the aluminum bracket I cut off my holset. If I had a good drill press it would have worked. Would have been one ghetto looking tool though. LOL.
I might still make it for ***** and giggles though.
Anyways good luck getting it back together!
dbsharp is offline
Old 04-08-2010, 04:05 PM
  #271
ashb82's Avatar
i will get it back together in about 2 weeks i got to order some parts
ashb82 is offline
Old 04-09-2010, 10:19 AM
  #272
ashb82's Avatar
Going with a H22 ATI Dampener. I think it will fit alot better than the other brands. Remeber this is a H2b Civic so i dont have alot of room
ashb82 is offline
Old 04-10-2010, 04:02 AM
  #273
something different
you'll love it. they really do wonders for your bearings on a higher HP setup.
Old 04-10-2010, 07:35 AM
  #274
GhostAccord's Avatar
I have been looking into using ether an ATI or Fluidampner. On Summit racing.com there is one thing that caught my attention in the item description about the ATI street dampener.
Originally Posted by summitracing.com
ATI Performance Products, the leader in race dampers, introduces the new ATI Super Street damper harmonic balancers. Manufactured for high performance street engines running below 5,800 rpm, they provide balanced dampening of torsional crankshaft vibrations throughout the rpm range.
here is the link;
Summitracing.com/ATI Super Street
5,800rpm??? I'm guessing that this must be a misprint. Anyone have any other specs on these? ATI lists a generic description for both the street & race. Doesn't say anything about RPM only that they are SFI 18.1 certified....
GhostAccord is offline
Old 04-10-2010, 02:56 PM
  #275
ashb82's Avatar
I called ATI friday they told me the street was the Same as the Race dampener, but with a bolt on pulley for power steering.I want be using the bolt on pulley. Thats the same one i ordered.
ashb82 is offline
Quick Reply: Turbo F22 build H22 rods 4g63 pistons low compression
