troubleshooting '99 P0117 code
My '99 accord with 195k overheated. Replaced the thermostat and heater hoses. Engine is running fine except for the P0117 code which could be the IAT sensor. Should I bother to replace the sensor or can I reset the check engine light - if that is possible. If the check engine light can be reset, please share the procedure.
Re: troubleshooting '99 P0117 code
you can check it with a multi-meter at operating temp (after the radiator fan has cycled at least once) you should see 0.4~0.7V. if in range reset the ECU as described above and continue driving. if it's not in range double check the thermostat and the rest of the work done on the cooling system. if all is good replace the sensor.
edit: oh, and don't forget the simple things like a loose or disconnected sensor wire...
mrchaikel
05-28-2006 06:15 PM
