Transmission won't split apart?? - Honda-Tech
Old 08-17-2008, 11:05 AM   #1
HImiles's Avatar
Default Transmission won't split apart??
Thank you for taking the time to read this. What a great site this is, very well moderated.
1991 Honda Accord LX 5-speed - 300k.
Please see the picture below. I have the trans out due to excessive trans noise. My problem is extremely similar to the trans noise AccordEX1991 was having in his post. Please see link below.
http://www.honda-tech.com/zerothread?id=1499813
I can not seem to get the transmission's belhousing to split any further than 3/4 of an inch, please see the picture or link to it. I'm not a trans guru by all means. Can you help me? Is it in gear?
http://viewmorepics.myspace.co...68271
HImiles is offline   Reply With Quote
Old 08-17-2008, 11:45 AM   #2
Working
-RedneckDave-'s Avatar
Default Re: Transmission won't split apart?? (HImiles)
You have to try and split the case all around and it should just, for lack of a better word, pop off. Are all the bolts holding it together out? Do you have a service manual?
-RedneckDave- is offline   Reply With Quote
Old 08-17-2008, 02:37 PM   #3
HImiles's Avatar
Default Re: Transmission won't split apart?? (-RedneckDave-)
Thanks for the response RedNeckDave.
All the bolts that keep the trans housing together are out. I'm sorry I had trouble posting the picture.
The casing is 3/4 of an inch apart all around. I even removed (then reinstalled) several other bolts on the housing just to be sure I have them all out. I've been afraid to really force the casing apart using a pry bar and leverage. Is that what it takes? Do they typically come apart with ease AFTER you initally pry the housing apart?
I do not have a service manual.... just a hayes manual.
Please let me know your thoughts.
It has nothing to with the fact that it may be 'in gear'???
Old 08-17-2008, 05:16 PM   #4
In a Junkyard near you.
Ross 2.0's Avatar
Can you post the pictures? I don't have myspace so I can't log in. If it's what i'm thinking you probably haven't released the circlip completely from the shaft bearing on the back side of the transmission. You'll need a friend or two to do it.
Have someone tap the case with a dead blow hammer (or rubber mallot), someone else fidget with the circlip and the other person try to jiggle the case off. It's a pain sometimes but it will come off.
Ross 2.0 is offline   Reply With Quote
Old 08-17-2008, 06:49 PM   #5
hurleyint's Avatar
Default Re: (Ross 2.0)
Figured I'd help.
hurleyint is offline   Reply With Quote
Old 08-17-2008, 07:50 PM   #6
Turbowa's Avatar
Default Re: (hurleyint)
If I'm looking at that pic. right and thats your tranny. You need to take the shift linkage out. There should be 4 10 or 12mm bolts holding the top on the little box. Once those are off. Pry off the top and inside you see were the shift lever is that goes through the side. Line up all the shift forks and you will see a 10mm bolt with a lock on it. Bend the tabs down on this lock and take the 10mm bolt out. Once that bolt is out then you can just pull the lever out.
Also make sure that the revers light sensor is out. There are also 2 or 3 bolts on the side of the case that hold springs and ball bearings in. You will need to take these out as well. Make sure that the Snap ring on the end gear stake is all the way off too.
There may be some thing else, but with out looking at one This is what I KNOW has to come off.
Turbowa is offline   Reply With Quote
Old 08-17-2008, 07:51 PM   #7
Ross 2.0's Avatar
Stand the transmission on the bell housing side, pull off the shifter assembly and try the steps I posted above.
Also go ahead and replace the distributor o-ring and the valve cover gasket.
CA 94 EG6 Drag Shell FOR SALE.... PICS INSIDE..... jaylux_virus Vehicles for sale 13 11-28-2009 09:39 PM
VTEC GO WAHHH INFO VTEC GO WAHHH Honda Civic / Del Sol (1992 - 2000) 11 08-21-2008 05:02 PM
can ne1 help me find my rim streetcartuner Honda / Acura 2 02-19-2007 02:07 AM
c of my car with da rims on streetcartuner Honda Civic / Del Sol (1992 - 2000) 4 02-13-2007 01:20 PM
clean silvia s14/sr20/volks/tein/ the works / socal jdmhondacrx Vehicles for sale 65 03-23-2006 04:09 PM
Tags
accord, acura, case, f22, gearbox, h22a, honda, howtotakeaparta1991honda5speedtranscaseapart, seperate, split, splitting, trans, transmision, transmission, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
