Transmission slips 1997 4cy automatic Honda Accord - Honda-Tech
Old 07-14-2011, 02:16 PM   #1
Default Transmission slips 1997 4cy automatic Honda Accord
when my 1997 4 cy automatic honda accord is hot, my tranny slipps out. Then I have to come to a stop, put in in my lowest gear, and i can build up some acceleration and get it back into my lower, regular drive. If I use my regular drive gear, my tranny will disingauge and my rpms shoot up.
I shut off my car and coasted for about 2 miles then parked it for about 10 minutes. when i got back in, the tranny seemed fine, for about 5 minutes, then it started doing it again.
It seems like when its cool, it works fine
has anyone had anything similur happen? someone told me it might be my tranny cooloer, something. I dont know.
DamTru is offline   Reply With Quote
Old 07-14-2011, 03:31 PM   #2
Jmb106jr's Avatar
Default Re: Transmission slips 1997 4cy automatic Honda Accord
I had similar issues w/ my 97 Cl. http://honda-tech.com/showthread.php?t=2944268
Jmb106jr is offline   Reply With Quote
Old 07-14-2011, 07:31 PM   #3
H-T Premium Sponsor
Synchrotech-Transmissions's Avatar
Check the fluid level and condition, it could just be low on fluid.
__________________
Synchrotech Transmissions / MFactory R&D
Carbon Synchros - LSDs - Torco MTF - Custom Builds - Gears - FD Sets - Rebuild Kits
Tech Support: David (909) 592-5900
www.synchrotech-transmissions.com
Synchrotech-Transmissions is offline   Reply With Quote
01 accord 4cy delay engage into gear help! Lucien Marks Honda Accord (1990 - 2002) 1 11-14-2016 11:04 PM
95 accord sedan automatic 4 cy. hesitates in 1st gear? heyman123 Honda Accord (1990 - 2002) 4 07-27-2016 12:25 PM
1996 Honda Accord 2.2, 4cy, camshaft position sensor mothornton Honda Accord (1990 - 2002) 7 01-27-2016 04:42 PM
Tranny wont stay in OD 92 honda ex Honda Accord (1990 - 2002) 6 10-22-2011 01:41 PM
98 Accord same stock engine swap now tranny problem... help??? cb1999nj Honda Accord (1990 - 2002) 3 03-14-2007 06:08 PM
Tags
1997, 97, accord, automatic, black, codes, gear, honda, intermittent, jumps, slip, slipping, stumble, tranmission, tranny, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
