Transmission jumps out of gear
Old 10-18-2011, 01:29 PM
hondaheartbreak's Avatar
Default Transmission jumps out of gear
Hav a 1992 accord ex 4 door 2.2L driving home from work running about 65 car felt like it dropped down to 3rd gear slowed down to 55 rpm 3500.
pulled over put car in park and the drive light was still on shifted in to all gears and drive light was still on ( park light on and drive light at same time)
eased on to home car shifted back up to 4th then back to 3rd where do i start to look for problem
Old 10-18-2011, 07:01 PM
phootbag's Avatar
Default Re: Transmission jumps out of gear
Faulty range switch.
Old 10-18-2011, 07:11 PM
P_Adams's Avatar
As Phootbag mentioned, you'll have to start with the Range Selector switch mounted to your console's shifter mechanism. You're fortunate (of sorts), these normally fail in such a way that the "Park" lamp never comes on and you can't get the key out!
Honda part # 35700-SM4-A92 1992 EX Auto / Federal
That will get you started
P
Old 10-19-2011, 06:23 AM
Thanks will give this a try
Old 10-19-2011, 06:16 PM
phootbag's Avatar
Before you replace the range switch, was the "D" indicator blinking or on solid?
Old 10-23-2011, 04:04 PM
light was on solid put new switch on but having same problem disconnected battery to reset when starting D4 light comes on brefiley thens goes off looks good from their pull gear down to D4 ok but when i pull down to D3 both light up and trans in in D3
Old 10-24-2011, 03:06 PM
checked a/t controll unit to see if any burnt parts found none will look at lock up solenoid and ground wires wed
Old 10-26-2011, 03:34 PM
checked lock up solenoids ohm out good tested to see if if they wore working tested ok changed trans oil went for test drive about 3 miles done fine then restarted a few hours later same problem checkin nm an nc speed sensor and tps sensor thur hope its one of them is the problem still no engine fault code
Old 08-11-2014, 03:59 AM
buster hyman jr's Avatar
I'm having the same issue, same vehicle, ever fix the problem?
Old 10-23-2015, 01:06 PM
Billy Samford's Avatar
hello i have a 98 honda civic LX and the problem is the transmission ... you start the car and then shift it down to drive it starts to go and then it jumps and then it will not go... give gas still will not go.. put in diff drive still wont go... put it back in park... kill the motor and wait about min or 2 start the car again and put it down in drive it goes and then does the same thing again
Old 10-23-2015, 08:52 PM
MM Gruppe B
MAD_MIKE's Avatar
Verify the fluid is within the has marks when the car is on level ground.
6th gen Civic AT dipsticks were built wrong and are VERY loose in the case, easily noticeable as the engine bay is usually pretty oily down by the dipstick.
If the fluid is full, and you have not have regular fluid changed, the sump filter may be impacted with friction material and sludge blocking flow. This is usually accompanied by howling or whirring sound coming from the torque converter area. This is the AT pump cavitating.
You may try draining and refilling the trans to remove the sludge, but when it gets this bad the filter is usually in need of replacement. This is not accessible without removing the trans to open the case.
Welcome to the Accord Forum.
BamaBleach
10-10-2022 05:36 PM
day_your
10-08-2007 09:42 AM
DAISIE'SACCORD
06-14-2007 12:04 PM
Ralphalot
04-21-2006 05:10 AM
Quick Reply: Transmission jumps out of gear
