transmission flush. - Honda-Tech
transmission flush.
Old 08-06-2010, 10:34 PM   #1
joe_accord23's Avatar
Default transmission flush.
i have a 5spd gearbox transmission on my accord. my question is how do i change the fluid? n wut type of fluid to use? wuld royal purple fluid word? on my manual it says it uses motor oil in the transmission help me!
joe_accord23 is offline   Reply With Quote
Old 08-07-2010, 01:44 PM   #2
Default Re: transmission flush.
The holes are visible when you take off the front right wheel. The filler bolt is a 17mm bolt that is just above and to the left of the drain bolt which is just a 3/8 drive bolt. I bought a plastic oil holding funnel and tube thing at Walmart in the automotive section for a few bucks that I used to fill up my transmission. You fill up a plastic piece that you can sit in the engine bay and then unlock the locking piece and it'll drain the oil through the tube into the fitting that you sit inside the transmission.
holmesnmanny is offline   Reply With Quote
Old 08-07-2010, 07:21 PM   #3
Quote:
thnx so its specifically for the transmission?...sounds good, and wut type of oil do i use? motor oil? royal purple trans? lemme kno plz
Old 08-07-2010, 11:40 PM   #4
Need to know exactly what kind of car you have, I forgot to ask in my first reply.
Old 08-07-2010, 11:49 PM   #5
There's a website for a local parts shop that gives good specs for most cars.
http://www.alliedautostores.com/Cata...logSubCat.aspx
Just put in your car and year and click on View Specifications at the top right.
Old 08-08-2010, 12:07 AM   #6
bseriescrxsi's Avatar
ive been using gear oil in my 5 spd trans...cant remember the verocity though....
bseriescrxsi is offline   Reply With Quote
Old 08-08-2010, 02:56 PM   #7
nus_dogg's Avatar
You can go with Amsoil GM Synchromesh or just go with Honda MTF.
nus_dogg is offline   Reply With Quote
Old 08-09-2010, 05:37 PM   #8
thnx alot u guys, i love this forum!
Transmission Fluid Bill Goodwin Transmission & Drivetrain 2 11-24-2012 08:01 PM
Help please Transmission fluid Quest Akavietboy201 Transmission & Drivetrain 6 09-12-2010 10:41 AM
Oil & Transmission Fluid??? chiaxi2002 Honda Accord (1990 - 2002) 13 12-13-2009 01:45 AM
civic 94, Power Steering Fluid, NEED HELP!! indee118 Honda Civic / Del Sol (1992 - 2000) 9 04-19-2008 11:56 PM
95 accord vtec how much transmission oil/fluid? technine Honda Accord (1990 - 2002) 7 06-13-2005 08:19 PM
Tags
1991, 91, accord, civic, cost, fit, flush, forums, honda, required, royal, tools, trans, transmission, walmart
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
