transmission fluid help!!!!!!!!
my cousin is stuck 200 miles from home and need to know what kind of tranny fluid to put in his 90 accord coupe manual tranny. help
Re: transmission fluid help!!!!!!!! (chrisgottigsr)
It doesn't (the manual ) say anything but this. Use only Honda fluid. But it also says that using engine oil can cause stiffer shifting, because it doesn't have the additives. But from what it says, you can use engine oil. So, if it were me I would try to find some generic manual fluid, if not, I would just get some 10w40 until I could drain it and put some Honda fluid in. Hope this helps.
Re: transmission fluid help!!!!!!!! (businessmanph)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by businessmanph »</TD></TR><TR><TD CLASS="quote">dexron 3</TD></TR></TABLE>
that's fu-king atf in a manual gear box
put in motor oil, honda stated it's okay for temporay use.
Re: transmission fluid help!!!!!!!! (YeuEmMaiMai)
They should have some kind of manual transmission fluid at pepboys. I changed the manual fluid in a nissan before, I had gotten the fluid from autozone though, I believe.
according to my accord manual, use API grade SF or SG engine oil and viscosity according to the chart. . .. which says '5w30 preferred' but 10w30 will work in warmer temps. hope ya get this in time
Heat
01-13-2015 11:35 AM
amorak
08-29-2006 01:52 PM
