Transmission fluid change on a 5-speed manual transmission?
Old 09-06-2005, 10:32 AM
Heat's Avatar
Default Transmission fluid change on a 5-speed manual transmission?
My ’99 LX only has 75,000 miles on it, but in another month I’ll have had it for seven years. Per the maintenance schedule, I was supposed to change the transmission fluid after 90,000 miles or six years.
My car is a 5-speed manual. Is there any transmission fluid in there that I’m supposed to change?
Old 09-06-2005, 12:31 PM
Stealthman80's Avatar
Default Re: Transmission fluid change on a 5-speed manual transmission? (Heat)
it should be in the manual, theres no plug tho I think you have to take the casing off
Old 09-07-2005, 12:10 AM
Ghostyman's Avatar
Default Re: Transmission fluid change on a 5-speed manual transmission? (Stealthman80)
Whoa... you have to take the casing off to change tranny fluid?
On most (all?) manual Hondas, there is a drain bolt located on the transmission. You can probably get to it from the front passenger side wheel well. I believe it takes a square 1/2" socket wrench to get it off. The fill hole is located above the drain hole.
Your best course of action is to pick up a Helms, Haynes, or Chilton book for your model Accord. It will come in handy for anything else you need to do.
imadigitalgod
187
04-23-2016 07:08 AM
professorman
01-23-2015 09:50 AM
Heat
01-13-2015 11:35 AM
DamonBoost
10-27-2001 02:28 AM
Quick Reply: Transmission fluid change on a 5-speed manual transmission?
