torque specs for the rocker arm assembly? 91 EXR - Honda-Tech
Old 03-30-2008, 01:50 PM   #1
Retep Draw's Avatar
Default l?
Are we absolutely sure on the torque specs for the rocker arm assembly given in the FAQ section? I'm working on my sisters' '91 EXR, replacing the spark plug tube o-rings on the bottom of the rockers, and don't have access to a manual. The first bolt I tightened was a 12mm. I attempted to torque it to 16 ft. pounds and the bolt snapped down at the half way point. GOOD TIMES! Also, the F22A6, the motor she has, is a three valve set up. Do the same specs apply to it? Thanx much
Modified by -RedneckDave- at 6:14 AM 3/31/2008
Retep Draw is offline   Reply With Quote
Old 03-30-2008, 08:22 PM   #2
hondadude's Avatar
Default ? (Retep Draw)
Sounds like the correct torque to me. Maybe it was just a flawed bolt?
Are you sure of your torque wrench?
hondadude is offline   Reply With Quote
Old 03-30-2008, 09:10 PM   #3
Retep Draw's Avatar
Default ? (hondadude)
Yeah, I am. But all the rest seemed the same as well. All the bolts seemed to "feel" like they were going to snap at that setting. The smaller bolts all seemed fine at the torque setting provided. Oh well, I'll pull the snapped one and try to keep them an eye on them. P.S. I guess that she does have a 4 valve per cylinder setup. The valve cover that stated 16 Valve should have given me an idea. DUHHHH!!
Old 03-30-2008, 09:23 PM   #4
Turbowa's Avatar
That does seem really high. I wouldn't much tighter then 8-10 ft/lb's. I know the civic only use aroudn 7 ft/lb's. 16 seems really high for me too
Turbowa is offline   Reply With Quote
Old 03-31-2008, 04:58 AM   #5
H-T Order of Merit
TouringAccord's Avatar
Default Re: ? (Turbowa)
for the F22Bx motors the torque spec shows 16ft/lbs on the 8mm bolts and 9ft/lbs on the 6mm bolts. I don't have the manual on the 90-93 Accords so...
TouringAccord is offline   Reply With Quote
rocker assy torque specs civic46 Honda CRX / EF Civic (1988 - 1991) 7 04-28-2010 06:43 AM
d15b2 rocker arm torque specs ef-it90 Honda CRX / EF Civic (1988 - 1991) 1 03-07-2009 05:26 PM
torque specs on d15? crxss outhe eyes Honda Civic / Del Sol (1992 - 2000) 0 01-24-2007 05:31 PM
torque specs on head anothersickhatch Honda Civic / Del Sol (1992 - 2000) 12 06-10-2004 03:26 PM
torque specs for d16y7. help! xXx Justin xXx Honda Civic / Del Sol (1992 - 2000) 6 04-01-2004 08:20 PM
Tags
91, accord, arm, assembly, civic, f22, f22a, head, honda, rocker, setting, spec, specks, specs, torque, tourque
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
