Torque bolt specs please
Could someone please provide the torque bolt specs for the following for a 1993 Accord f22A1 engine
Connecting rod bolt torque spec
12 and 10 mm rocker arm bolt torque specs
Thank you
Thank you
Re: Torque bolt specs please
I have a 97 Accord with the F22B2 motor. For the valve rocker assembly, the 10mm bolts are 9 ft lbs, and the 12 mm bolts are 16 ft lbs. I just did the spark plug seals and needed to remove it. Not sure on the connecting rods. Hope that helps.
My Haynes for the 94 to 97 says 34 for the cap nuts on the 4 cylinder and 33 for the V6. That's the closest I could find for the rocker arm.
uberEFtuner
03-02-2012 07:01 PM
ray.riddler92
07-27-2011 05:07 PM
onwisconsin81
04-05-2010 01:25 AM
Retep Draw
03-31-2008 03:58 AM
