tire size, how important and what about mpg
Old 08-20-2007, 08:56 AM
nauc's Avatar
Default tire size, how important and what about mpg
just bought a 99 accord 4 cylinder, it has 205's on it, the manual says 195, they look brand new
will it be ok to use them, or am i setting my self up for something
my road trip says im getting about 23mpg overall, its the vtec manual lx 4 cylinder sedan, should be upper 20s iirc
any thoughts on this
thanks
Old 08-20-2007, 09:12 AM
02 accord's Avatar
Default Re: tire size, how important and what about mpg (nauc)
205/what/15? I'm running 205/60/15 on my 02, and I'm getting upper 20s, low 30s mpg. By the way, this is on an automatic.
Old 08-20-2007, 11:02 AM
nauc's Avatar
Default Re: tire size, how important and what about mpg (02 accord)
yah 15's..........
Old 08-20-2007, 11:06 AM
Bruce Banner's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nauc &raquo;</TD></TR><TR><TD CLASS="quote">yah 15's..........</TD></TR></TABLE>
what # b4 the 15
Old 08-20-2007, 11:32 AM
361 accord's Avatar
Default Re: tire size, how important and what about mpg (Bruce Banner)
naa that "plus sizing" thing is ok, any tire that stays within 3% of OEM tire circumfrence is OK, they say if u get too big of tires it can cause brake failure, but i think thats for people who put those monster truck tires on their trucks and stuff like that
also: i already asked George Knighton about that, getting the 205's or 215's in a lower profile (to maintain the sidewall thickness) to get a wider tire, said it wont really help straight line acceleration because the contact patch's AREA will remain the same, just the shape will change
however you should feel a difference in cornerin since a wider contact patch will grip more under lateral acceleration
Old 08-20-2007, 07:52 PM
JimBlake's Avatar
Default Re: tire size, how important and what about mpg (361 accord)
Still depends on that middle number in the tire size.
205/?? R15.
And what make & model of tire. It's not only the size. Some tires have more internal 'friction' so they make a small difference in the overall drag the engine has to work against.
Old 08-20-2007, 08:06 PM
nauc's Avatar
Default Re: tire size, how important and what about mpg (JimBlake)
i think i have the 205 65R 15's vs the 195 65R 15's
Old 08-20-2007, 09:24 PM
361 accord's Avatar
err thats gonna slow you down
205 or 215/60-15 would be better
Old 08-21-2007, 12:02 AM
wrenchy's Avatar
I think the 205/65/15 tire may have a smaller overall diameter than the 195/65/15. My stock tires were 195/70/14's, an almost exact match to the 205/60/15's I installed. The stock rims were 14's (the last number), the replacement rims 15"
The best thing is to match the overall rim/tire size so the overall diameter is the same. Increase the rim size, you should decrease the tire-height, so you go 'lower-profile' on the tire. The lower/wider tire gives better cornering.
If you run smaller overall diameter, the engine/tranney will have to run higher RPM's for any set speed, so you will be pushing the drivetrain harder and burning more gas.
If the overall diameter is larger, you will run at lower RPM's at cruising speeds, so you might save some gas. The problem with this is it takes greater TORQUE to start the wheels turning, and this is very hard on clutches and tranneys.
The overall rim/tire diameter is very carefully engineered to the engine/tranney, so changing it much can really have negative impacts on the engine/tranney. This is one reason why "monster" trucks with huge wheels/tires have more HP/torque-to get the wheels turing from a dead-stop.
Install "mini-wheels" on a car, and it may look cool (I guess some think so), but you may be running 3400 RPM at 70 MPH when you used to cruise at 3000 RPM at the same 70 MPH. The extra 400 RPM will eventually wear the engine/tranney faster.
Call a tire shop, and ask for the tire heights for your stock and the replacements. If the replacements are smaller in diameter, you will run higher RPM's to get the same speed, so you will be burning more gas. If the tires are within 1/8" there should be no problem, but your speedo will be slightly off. Wrenchy
Old 08-21-2007, 06:53 AM
nauc's Avatar
again, i didnt pick the 205's, its what the car came with, but was just wondering cause my mpg seems low
LoneAutosport
05-08-2009 08:26 AM
PinoyDelS0l
07-11-2008 02:47 PM
DCFIVER
03-08-2005 10:00 AM
MAFA
02-18-2004 07:29 AM
combustion
11-06-2003 07:21 AM
Quick Reply: tire size, how important and what about mpg
