Timing belt replacement
Old 06-23-2010, 09:11 AM
gnx547's Avatar
Default Timing belt replacement
I need to replace the timing belt soon on my 01 Accord, 4 cylinder. I was wondering is there a write up procedure on this forum on replacing the timing belt? Thanks
Old 06-23-2010, 09:35 AM
AaronRVegas's Avatar
Default Re: Timing belt replacement
i dont know what year(s) it was for but i saw a video on youtube about this. try searching that. just fyi i think it can be a pretty difficult job if you dont know what you are doing.
edit: did not realize i added the link to favorites lucky you here is the link
http://www.youtube.com/watch?v=EmasxgJdXJ8
Old 06-23-2010, 09:49 AM
The-Kid's Avatar
You can probably follow the 90-97 Accord writeup. It is about the same. You can buy a complete writeup from this YouTube person, he goes step by step. I saw it on his website http://www.ericthecarguy.com/fix-it/ I never seen the video, but his other videos are really detailed and he shows you tips.
For me, I used the DIY 90-97 Accord Timing belt change (in the Accord FAQ) when I changed my 01 Accord timing belt
Old 07-23-2010, 01:42 PM
gnx547's Avatar
Just making sure, what is the service interval for the timing belt? Is it 90,000 miles?
Old 07-23-2010, 02:36 PM
nus_dogg's Avatar
Yeah, I believe its 80,000-90,000 mi. Do the Water Pump while you're at it too.
Old 07-23-2010, 09:36 PM
H-T Order of Merit
TouringAccord's Avatar
just use my write-up in the FAQ, it's better than that video
seriously though, you can print the instructions from a PDF download that is linked in the write-up, that way you can have it with you while working on the car.
Old 07-23-2010, 09:59 PM
harveyjerry's Avatar
Timing belts are very important. They control the valves and pistons of the machine. If the timing belt should break pistons can drain valves, which break the engine in a way that would cost much expenses we are talking about 2000-3500 dollars. Your car is about twice the mileage that the timing belts should be replaced. Consider that you have a sense.
Old 07-24-2010, 12:01 AM
GunSamir's Avatar
I followed this video and some guidelines from the Honda Accord repair manual and was able to succesfully replace the timing belt on my F18B3. I never did a timing belt before on any car. This video is very helpful.
Two400
01-22-2008 04:10 PM
swapped95
10-13-2006 08:27 PM
NewfieAccordEXR
09-03-2006 01:06 PM
Goofyboy
10-19-2004 06:25 PM
Quick Reply: Timing belt replacement
