Timing belt replace, not tight. - Honda-Tech
Old 04-16-2012, 02:23 PM   #1
Default Timing belt replace, not tight.
I recently did a timing belt/water pump replacement on my 2001 accord lx 2.3l. How do you tighten the belt properly with the auto tensioner? It's weird compared to other cars that have a spring load.
yankie_1132 is offline   Reply With Quote
Old 04-16-2012, 03:24 PM   #2
fubuallstar's Avatar
Default Re: Timing belt replace, not tight.
i just loosen the tension bolt a lil and retighten it while guiding tensioner to the desired tighteness then i tighten the support screws on the lil handles. go on youtube theres a few 6th gen how to's so you can see what im talking about
fubuallstar is offline   Reply With Quote
Old 04-17-2012, 04:33 AM   #3
H-T Order of Merit
TouringAccord's Avatar
should be the same procedure as the one outlined in the timing belt write-up in the faq thread.
TouringAccord is offline   Reply With Quote
Timing belt tensioner ke7joi Classic Hondas 4 07-16-2014 08:51 AM
timing belt skips vtec_01 Acura Integra 5 12-12-2011 06:14 PM
Timing belt replacement gnx547 Honda Accord (1990 - 2002) 7 07-24-2010 01:01 AM
timeing belt alfamotorhd Honda Accord (1990 - 2002) 3 11-08-2008 11:39 AM
91 Accord EX Timing Belt SPL KID Honda Accord (1990 - 2002) 1 04-16-2004 08:34 PM
Tags
1988, accord, belt, belts, change, civic, diagram, ep3, honda, location, pump, si, timing, wagovan, water
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
