TIMING BELT
Old 11-19-2005, 04:55 PM
accordlover's Avatar
Default TIMING BELT
when should I change My belt? At what Miles?
Old 11-19-2005, 05:08 PM
Stealthman80's Avatar
Default Re: TIMING BELT (accordlover)
500,000 miles
Old 11-19-2005, 06:13 PM
hondadude's Avatar
ummmm, aahhhhhhh, well; YES, SORTA, MAYBE.
All that other info you provided is sort of overwhelming.
Old 11-19-2005, 07:09 PM
YeuEmMaiMai's Avatar
for 5th gen cars it is 90K for the first one and if you had your belt changed recently the placement is good for 105K (according to Brooklyn Honda in the twin cities MN)
For the newer cars I believe that it is 105K for the 4cyl and 120K for V6 models
Old 11-19-2005, 08:15 PM
Schmitey's Avatar
Default Re: TIMING BELT (YeuEmMaiMai)
whenever you want to
Old 11-19-2005, 09:00 PM
soon2bdropped's Avatar
Default Re: TIMING BELT (Schmitey)
every 90k i believe.. i neglected to do so and lost my car
Old 11-20-2005, 09:12 AM
Default Re: TIMING BELT (soon2bdropped)
Wu=ill that belt ever just rip apart while I'm drivin?
1999 Honda Acccord 2dr EX
98000
Old 11-20-2005, 10:10 AM
SteveoBA8's Avatar
it could and them that means $$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$ $$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$ so replace it
Old 11-20-2005, 10:20 AM
Default Re: TIMING BELT (SteveoBA8)
Is it easy to do it yourself?
Old 11-20-2005, 11:46 AM
SteveoBA8's Avatar
if your good mechanically then you can do it, and i dont mean you can change oil and thats it. Get a manual
Old 11-20-2005, 03:16 PM
if that belt snaps you are gonna spend some serious cash to either replace or repair the engine. 98K should be ok on that car if you are an average driver and do not abuse it.... otherwise replace it. I believe that the belt is good for 105K for that year....
Old 11-21-2005, 12:27 PM
Chi
Chi's Avatar
Changed mine @ 110 a little late but no biggie.
It's not too hard to do just make sure you have all the tools nad make sure you change all the parts necessary along with it and not just the timing belt
Old 11-21-2005, 01:39 PM
piwko's Avatar
Default Re: TIMING BELT (Chi)
What exactly do you need to change other then the water pump and timing belt when doing this... I heard about a few other things
dave
Old 11-21-2005, 02:41 PM
Chi
Chi's Avatar
Default Re: TIMING BELT (piwko)
For the 6 you'll wawnt to do the tensioner, other drive belts, replace your coolant and I believe it's the cam gear seal. Once you have the water pump off you'll see why, everything is right there and might as well. I've heard stories of tensioner failure that prompted me to change mine when i was doing the Tbelt replacement. Also a good time if you want to change out your crank pulley and install cams.
Old 11-21-2005, 02:54 PM
CRXb18Turbo's Avatar
I do it every 5 years.
That average 85k
Old 11-21-2005, 02:57 PM
THATS CHELLA **** MY POCKETS AREN'T THAT DEEP
Old 11-21-2005, 04:23 PM
piwko's Avatar
thanks for the reply
the accord is a 98, so i might as well and replace all those parts you mentioned. I wont do the cams though i'll let those be as is. You guys have a place where you can buy all these parts cheap?
dave
Old 11-21-2005, 04:28 PM
I would replace any wearable part that comes off such as
Drive belts
water pump
tensioner
Old 11-21-2005, 06:56 PM
JTB
JTB's Avatar
do you have a v6 or l4? if you are in severe cond. its 90,000 if u r not in severe its 105,000
Old 11-21-2005, 07:02 PM
Default Re: TIMING BELT (JTB)
I have a 94 and the change milage is 90K. However the replacement belts are good for 105K. I do not drive in severe conditions
Old 12-01-2005, 06:35 PM
it's a V4
Old 12-01-2005, 06:43 PM
Defcon2030's Avatar
what's a v4?
i4?
Marjan
08-08-2017 08:11 AM
dgdarien
25
12-31-2009 11:18 AM
csc67
02-21-2005 08:39 AM
Fink2iCe
10-06-2004 09:23 PM
HuKaShI
12-01-2003 12:14 PM
Quick Reply: TIMING BELT
