tdc
Old 08-13-2005, 02:10 PM
pigdicker's Avatar
Default tdc
how do i set my #1 cylinder at tdc
Old 08-13-2005, 03:11 PM
NAiL05's Avatar
Default Re: tdc (pigdicker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pigdicker &raquo;</TD></TR><TR><TD CLASS="quote">how do i set my #1 cylinder at tdc</TD></TR></TABLE>
You should search around. What car is this for?
Old 08-14-2005, 07:33 AM
deserthonda's Avatar
on ur particular year and model u need a gonko-meter
Old 08-14-2005, 01:51 PM
lilneedle's Avatar
I WOULD SAY ...TAKE YOUR BELT OFF AND REMOVE YOUR #1 SPARK PLUG. THEN STICK A PEN OR PENCIL IN THE PLUG HOLE $ AND SPIN YOUR
CRANK PULLEY ,UNTIL THE PISTON IS ALL THE WAY UP AND GETTING READY TO GO BACK DOWN.. YOU'LL FEEL IT.....GOOD LUCK.
Old 08-14-2005, 04:07 PM
tyro's Avatar
Default Re: tdc (lilneedle)
uhh, pencil won't be long enough. Need something longer or you'll lose that pencil.
How is he going to know if it's on the compression or exhaust stroke?
Best yet...original poster...take $15 and get a haynes manual or go another 50 and get a Helms
Old 08-20-2005, 02:09 AM
i_kick_turtles's Avatar
Default Re: tdc (Buck Turgidson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lilneedle &raquo;</TD></TR><TR><TD CLASS="quote"> I WOULD SAY ...TAKE YOUR BELT OFF AND REMOVE YOUR #1 SPARK PLUG. THEN STICK A PEN OR PENCIL IN THE PLUG HOLE $ AND SPIN YOUR
CRANK PULLEY ,UNTIL THE PISTON IS ALL THE WAY UP AND GETTING READY TO GO BACK DOWN.. YOU'LL FEEL IT.....GOOD LUCK. </TD></TR></TABLE>
thats how I do it but with a flathead screwdriver
Old 08-20-2005, 05:05 AM
H0ndaJunkie's Avatar
Default Re: tdc (I R Tylor)
This is a little more time consuming, but it's a nice visual method.....instead of trying to feel with a screwdriver. Take off your valve cover, and the top half of the timing belt cover, so that you can see your cam gear. Then, Stick a ratchet with a socket and extension through the hole in the splash guard, onto your crank pulley bolt. Turn the crank pulley anti-clockwise, until the word "UP" is straight up and the two little lines on the edge of the cam gear line up with the top of the head.
Old 08-20-2005, 09:05 AM
remove distr cap. spin engine till rotor point s to # 1 plug wire on cap , very easy to chk , the valve cover removal method is good but too much work ,no need to remove valve cover, as for putting a screwdriver in the cylider and feel if it is on top ,remember when u are on top dead # 4 ,,, the # 1 piston is also up so u cannot tell for sure if u are top dead # 1 or top dead # 4 . u could be 180 degree off
Old 08-20-2005, 01:28 PM
syclone's Avatar
Default Re: tdc (deserthonda)
well.. the simplest way is to remove your cam gear cover and look at the word etched in the gear saying 'UP'... when it's pointing straight up, it's at tdc for the #1 piston.. then you rotate it 1/4 for tdc #2, and so on..
Old 08-20-2005, 04:03 PM
sauceja's Avatar
And which belt should he take off? Let us take the timing belt off and start turning the crank. This will be interesting.
LOL
EK4_K20
01-30-2008 01:18 PM
spoolin_teg
10-28-2006 01:46 PM
GarageAlchemist
02-24-2006 12:03 PM
silentbeatz
08-21-2005 10:38 AM
B18ls*RAYON
Acura TL, RL & ZDX
21
07-05-2005 02:13 AM
Quick Reply: tdc
