Switching from Conventional Oil to Synthetic Blend. - Honda-Tech
Old 08-22-2006, 11:40 AM   #1
Corruption's Avatar
Default Switching from Conventional Oil to Synthetic Blend.
Hey guys, I have a few questions concerning the oil I'm about to put in my F23A4. Since 25k miles (There's currently 63k miles on the block), since I've had it that is, I've put just regular old oil in the car. My last oil change I put in Castrol GTX with an K&N Oil filter. I was wondering whether there would be any problem with switching to Castrol GTX Synthetic Blend and whether it would cause any problems to my engine? I plan on switching to Full Synthetic once I've put in Synthetic blend for about 20k miles or so? Is this ok?
Corruption is offline   Reply With Quote
Old 08-22-2006, 12:24 PM   #2
notoriousB's Avatar
Default Re: Switching from Conventional Oil to Synthetic Blend. (Corruption)
screw the blend and just swap right to full synthetic. there is no issue with doing that.
most "blends" are like 80% conventional oil anyway, a marketing scam.
notoriousB is offline   Reply With Quote
Old 08-22-2006, 08:43 PM   #3
Corruption's Avatar
Would there be any problem with using syn blend this oil change and then throw in full syn next time? What are you currently running in your f23a1 notorious?
Old 08-22-2006, 09:11 PM   #4
RTFM
there is no probelm changing you roil. doesnt matter if its synth, blend or dino oil.
v4lu3s is online now   Reply With Quote
Old 08-22-2006, 09:50 PM   #5
iam7head's Avatar
Default Re: (v4lu3s)
Quote:
ONLY if the motor is fully broken in
you don't have to step up with synblend, and yes B's right about syn blend, the ratio is around 8:2 if not lower.
most car doesn't need syn. oil, the dino oil today is so much advance than old oil formula from past.
iam7head is offline   Reply With Quote
Old 08-22-2006, 10:32 PM   #6
Corruption's Avatar
iamhead, what the hell are you talking about? All I want to know is if it's safe to use this oil that I just bought and then use full syn next time?
Old 08-23-2006, 06:56 AM   #7
New User
urbanlegend21's Avatar
Default Re: (Corruption)
Quote:
Yes, it is safe. I'm not sure why you want to spend more money than you have to but, yes, it's safe.
urbanlegend21 is offline   Reply With Quote
Old 08-23-2006, 07:46 AM   #8
ricebike's Avatar
Default Re: Switching from Conventional Oil to Synthetic Blend. (notoriousB)
got any links to that percentage of dino-synthetic ratio? just curious...
ricebike is offline   Reply With Quote
Old 08-23-2006, 07:52 AM   #9
notoriousB's Avatar
you can switch from blend to full synth next change no worries.
I am using Royal Purple 5w30 full synthetic, but that's because I've got a built motor and boost the **** out of it. I ran it on dino oil for breakin, started w/ 10w40 for 3 oil changes (1st one within 20 miles!), went to 10w30, and finally after 3k+ miles changed to full synth.
Honda Civic oil pan gasket/oil leak aquemini Honda Civic / Del Sol (1992 - 2000) 22 11-13-2015 03:17 PM
Changing to Synthetic Jimster480 Honda Civic / Del Sol (1992 - 2000) 14 08-20-2009 03:15 PM
Synthetic oil to Synthetic blend? bad idea? itr1244 Acura Integra Type-R 12 04-04-2007 07:01 PM
Synthetic oil analysis - extended oil change AutoXer Honda Civic / Del Sol (1992 - 2000) 13 09-08-2005 01:11 PM
Any oil recomendations? piotrush Honda Prelude 5 05-07-2002 06:12 AM
Tags
acura, blend, changing, conventional, full, gtx, oil, problems, regular, safe, silverado, stnth, switch, switching, syn, synthetic
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
