sway bar bushing replace?
Old 11-06-2007, 04:22 PM
dtran002's Avatar
Default sway bar bushing replace?
hey all, just wondering how hard is it to replace those bushing? Do I need any special tools? Or it just unscrew the bolt, replace the rubber part and screw the bolt back on? It for a 95accord lx lower front sway bar.
Thanks
Old 11-06-2007, 04:30 PM
YeuEmMaiMai's Avatar
Default Re: sway bar bushing replace? (dtran002)
standard handtools should work fine. I thought you have to remove the bar, grease the bushing and slide it over the bar, no?
Old 11-06-2007, 04:37 PM
The-Kid's Avatar
Default Re: sway bar bushing replace? (YeuEmMaiMai)
Pretty easy. I suggest keeping the 2 wheels off the ground. Obviously sway bar is to make the car level, and when you take jack up 1 side, it's gonna push down on the that jacked up'ed side.
Anyways remove the 2 bolts holding the bushing. You do not need to remove the swaybar connections at the suspension arms. The bushing itself has an opening, like a cut in it. take it out, put it in and there you go. 30 mins i think.
Old 11-06-2007, 04:53 PM
Default Re: sway bar bushing replace? (The-Kid)
cool beans on the update but regardless prease that puppy up before installing it
Old 11-06-2007, 05:49 PM
dtran002's Avatar
cool, thank you all
Old 11-06-2007, 05:51 PM
Banned
jakeiscool's Avatar
go for poly!
that reminds me.....Note to self: Replace sway bar bushings and sway bar.
tdhjrh
04-05-2017 05:58 AM
NovaRex
05-23-2016 07:17 AM
phil_lt1
11-08-2009 08:33 PM
H22PreludePhil
05-06-2008 03:12 PM
pyrojeff
04-25-2005 06:31 AM
Quick Reply: sway bar bushing replace?
