swap h23a1 to 95 honda accord ex - Honda-Tech
Old 03-19-2017, 06:02 AM   #1
Default swap h23a1 to 95 honda accord ex
I'm currently swapping a h23a1 into my accord. I'm wondering does it matter if the ecu came from a 94 prelude and the motor is from a 96? And I'm also wondering where the best place is to look up wiring diagrams because there is a few things i have to wire up since the wires were cut.
derickweber is offline   Reply With Quote
Old 03-20-2017, 03:45 AM   #2
Default Re: swap h23a1 to 95 honda accord ex
I believe the H23A1 Prelude motor is not-VTEC and the 95 EX is, so that will be a problem. And the H motor uses different tuning for the motor, so that will be a problem. You need an ECU for the motor you will be using, or one chipped for tuning.
Fitz Williams is online now   Reply With Quote
Old 03-20-2017, 04:38 PM   #3
reuse the f22b1 harness leave the vtec connectors hanging Does your f22b1 have a knock sensor? if not u need to wire that up. the ecu u want is a P14 auto or manual what ever your car is.
HondaTechMan121 is offline   Reply With Quote
someone help!! vtech vs non vtech jsamtate Honda Accord (1990 - 2002) 1 01-01-2013 05:24 PM
H23 vtec hondaaccordf23 Honda Accord (1990 - 2002) 21 11-26-2012 11:11 PM
I have a 92 prelude automatic and want to install h22 perseverance Honda Prelude 3 12-08-2010 03:48 PM
harness diagram h23a1 mixmastermatt Honda Prelude 5 01-10-2007 06:24 PM
H22A or H23A in a 92 Accord Superman137 Honda Accord (1990 - 2002) 28 06-29-2004 11:06 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
