stuck in park - Honda-Tech
stuck in park
Old 02-25-2010, 06:42 PM   #1
Default stuck in park
my car got stuck in park today. i press the break still wont shift. so what i had to do is cut the car off and pull the e-brakes up and put and car in N and start. then i out in in drive. but when i put back in park get stuck again. i cut the car off for about 10 minutes started the car in got out of park with no problem. what can this be
FreshCD5 is offline   Reply With Quote
Old 02-25-2010, 07:07 PM   #2
GDD Member
slomofo's Avatar
Default Re: stuck in park
Neutral Safety Switch
OR
Shifter cable adjustment.
slomofo is offline   Reply With Quote
Old 02-25-2010, 08:49 PM   #3
Quote:
OR
its an automatic to let you know
Old 02-25-2010, 08:52 PM   #4
lobudgetr's Avatar
It sounds like that stupid switch that sits on the brake pedal may be going bad.
lobudgetr is offline   Reply With Quote
Old 02-25-2010, 09:00 PM   #5
matt96ex's Avatar
its probably the shift interlock solenoid. do you hear a click noise when you press on the brake pedal?
matt96ex is offline   Reply With Quote
Old 02-25-2010, 09:02 PM   #6
redbull-1's Avatar
Yes, probably the brake light switch. The plunger on the switch may have deteriorated/broken off.
See this link for this guy's cheap fix:
http://ldsdates.com/blog2/2007/09/18...-light-switch/
You can always replace it too.
redbull-1 is offline   Reply With Quote
Old 02-25-2010, 09:09 PM   #7
redbull-1's Avatar
See this:
Old 02-25-2010, 09:25 PM   #8
Quote:
i was not getting it i had to cut my car off put it in N the start the car cut it back off for like 10min then start back came out of park with no problem started to get the interlock
Old 02-25-2010, 09:26 PM   #9
Quote:
Originally Posted by redbull-1 View Post
See this:
thats what am going to do
Old 02-26-2010, 12:55 AM   #10
On the shift lever console you may find a little lid: if you remove it you can use a pin to manually override the blocking of the shift lever in P. This override procedure is also described in the owner's manual.
Dannyvho is offline   Reply With Quote
Help!! Savannahs mommy Honda Accord (1990 - 2002) 3 09-06-2015 06:22 PM
Help: Can't remove key without disconnecting battery and shifter stuck in park mistersink Honda Fit 13 07-15-2014 12:18 AM
96 honda accord ex-v6 auto transmission stuck in park. rbwdriven Honda Accord (1990 - 2002) 17 10-22-2008 06:58 PM
computer problems? doeboy6587 Honda Accord (1990 - 2002) 3 04-03-2006 11:02 AM
Friend's automatic 97 accord get's stuck in park daily; why???? Cliffjumper2 Honda Accord (1990 - 2002) 3 10-08-2004 07:53 PM
Tags
2001, 2003, car, crv, gear, geo, honda, metro, neutral, odyssey, park, pilot, replace, safety, stuck, switch
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
