stripped valve cover bolts - any easy fix? - Honda-Tech
Old 03-04-2012, 05:57 AM   #1
Default stripped valve cover bolts - any easy fix?
What would I do if the head side of the valve cover is stripped. I have a 94 accord vtec. The 2 front head holes are stripped.
Joshgb is offline   Reply With Quote
Old 03-04-2012, 07:04 AM   #2
DelSol-B18's Avatar
Default Re: striped valve cover bolts any easy fix
Tap it with bigger threads
DelSol-B18 is offline   Reply With Quote
Old 03-04-2012, 08:23 AM   #3
Resident Gearhead
BryanM.'s Avatar
Quote:
Helicoils.
BryanM. is offline   Reply With Quote
Old 03-04-2012, 08:55 AM   #4
Quote:
If you tap it with bigger threads, then you would need a larger diameter valve cover bolt right, but those bolts are specialized from honda for that application, at least for the d16y8 and dseries motors.
motegicivic is offline   Reply With Quote
Old 03-04-2012, 09:20 AM   #5
That's what I'm saying if you tap the head where do you get bigger vavle cover bolts.
Old 03-04-2012, 12:18 PM   #6
Texas4door's Avatar
If you use a helicoil, the INSIDE thread diameter will remain the same as the original threads
Example, if you had to use a M10 diameter bolt, and the threads stripped out, you'd get a M10 size helicoil that will match the original inside diameter of the threads
DO NOT tap out larger threads here; it's not needed on something like this because they don't require that much torque
...and let's say you already did, in that case, go to the hardware store and match up the original valve cover bolt length with a new bolt+washer
The put your new grommet on your new bolt+washer and tighten it down
Simple, just remember which bolt goes where if you take the cover off again
And yes, Speeder Wrench ftw!
(or a nut driver will work too)
Texas4door is offline   Reply With Quote
Old 03-04-2012, 05:21 PM   #7
deving916's Avatar
so what fixes this? On my old car, the top had to be cut off in order to get the VC off and then this wouldn't come out of its hole.
deving916 is offline   Reply With Quote
Old 03-04-2012, 05:25 PM   #8
Texas4door's Avatar
Oh ****, well you're in a better position than I thought!
Most people with this problem have it broken off below the level of the top of the cylinder head, but you're lucky here!
Just grab that thing with some vice grips and turn it out of the hole, but don't break it off!
Then get the new bolts from Honda or the hardware store if you're feeling cheap
Simple!
Old 03-04-2012, 05:36 PM   #9
deving916's Avatar
this was on my old car, but i sold the car because this situation set me over the edge, just curious to see if it was an easy fix or not.
Tried vice grips and it wouldn't budge.
Old 03-04-2012, 05:45 PM   #10
Texas4door's Avatar
Is the stud EXACTLY like this?
Is so, you could try using a wrench on the hexagonal bit near the bottom of the stud.
A picture of your problem would certainly lead to better solution suggestions
Old 03-04-2012, 05:47 PM   #11
Arthas's Avatar
Youre in luck thats a SUPER EASY fix.
A 12mm brake line wrench would get that off without an issue. Then grab a new one from a junkyard and youre done!!!
If it was the threads on the head, you would just heli coil them.
Arthas is offline   Reply With Quote
Old 03-04-2012, 05:50 PM   #12
deving916's Avatar
i tried to use vise grips but they would just turn and the bolt wouldn't move. the second long bolt on the other side broke off in the threads though.
Old 03-04-2012, 06:01 PM   #13
Arthas's Avatar
Stick a skinny flat head in between the bolt and the head and try turning again.
Old 03-04-2012, 09:03 PM   #14
Does any body know what size helicoil set I would need to fix the threads in the head for the valve cover. I'm not sure what size the bolts are. I'm going to take them with me but maybe one of you guys could help. It's a 94 accord vtec.
Old 03-04-2012, 09:31 PM   #15
Arthas's Avatar
I believe its M6.
Old 03-04-2012, 11:15 PM   #16
I'll have to check it out tomarrow. But thanks.
Old 03-04-2012, 11:40 PM   #17
Texas4door's Avatar
If it's a 94 Accord, shouldn't this be moved to the Accord section so we don't get crossways with our info?
Old 03-05-2012, 07:52 AM   #18
90Rexx's Avatar
here you go. Get a set of these when u put your valvecover back on dont reuse those rubber washer things.
http://cgi.ebay.com/ws/eBayISAPI.dll...e=STRK:MESE:IT
90Rexx is offline   Reply With Quote
97 Civic HX - stripped valve cover bolts and head CJaramillo22HX Honda Civic / Del Sol (1992 - 2000) 15 11-06-2015 04:37 AM
stripped acorn nut untitled23 Acura Integra 16 04-29-2010 03:36 PM
Help! Stripped head bolts or studs and need to remove Chrome Valve Cover lmike6453 Acura Integra 20 03-14-2008 09:00 AM
FS: B-series Vtec Valve Cover (stripped paint) G U E C O For Sale 4 02-12-2004 01:26 AM
Suggestions on stripped valve cover bolts (threads in the head) VXpride Honda Civic / Del Sol (1992 - 2000) 4 07-31-2003 09:53 AM
Tags
94, accord, acura, bolt, bolts, civic, cover, find, front, head, honda, integra, set, size, stripped, stripping, studs, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
