Brake Problem
Old 04-02-2008, 07:31 PM
m3 mark's Avatar
Default Brake Problem
I have a 96 accord lx no abs. Brakes engauge very low. Checked for leaks n0 external leaks found. fluid level is good. I replaced the brake M.C. bench bled. And bled and bled the brake system. rr lr rf lf. But the brakes are still engauging very low. im positive there is no air comming out of the bleeders. I have a clear tube in a clear bottle submurged in b.f. with no bubbles. I went through 2 big bottles of b.f. I have also cracked the two output lines from the m.c. to further bleed the system.with no luck can air get traped in the distributing valve? has anyone seen this?
Old 04-03-2008, 02:15 PM
hondadude's Avatar
Default Re: Brake Problem (m3 mark)
Aftermarket M.C.?
You might need to adjust the push rod under the dash. Don't adjust it too long or the brakes will drag all the time.
Try about 1/2 turn at a time, then test drive.
Old 04-21-2008, 05:01 PM
teggy182's Avatar
Default Re: Brake Problem (hondadude)
weird problem bump for an answer
Old 04-21-2008, 06:17 PM
burton_o6's Avatar
I'm having almost this exact problem. There is almost no pressure when I engadge the brake(while the car is on). We bled the brakes for nearly an hour and went through tons of bf. Do your brakes work at all? I have been having to use my E brake lately.
ThagAnderson
06-28-2007 12:41 PM
zcivicz
04-08-2005 07:40 PM
digitalayon
03-13-2005 02:48 AM
SSBP DC2
06-16-2003 12:29 PM
91SE
08-19-2002 08:10 PM
Quick Reply: Brake Problem
