Steering Wheel Removal. 2000 Accord SE. - Honda-Tech
Old 08-03-2006, 01:18 PM   #1
garaged_Si's Avatar
Default Steering Wheel Removal. 2000 Accord SE.
Anybody Know how to remove the steering wheel? couldnt find the topic about this so i just started new Topic's. Want to install a quick release but not really sure how to remove the steering wheel. Any help will be appreciated, Thanks.
garaged_Si is offline   Reply With Quote
Old 08-03-2006, 01:35 PM   #2
philadd's Avatar
Default Re: Steering Wheel Removal. 2000 Accord SE. (garaged_Si)
1. Make sure to park the car with wheels straight.
2. Disconnect negative battery cable, and then positive cable.
3. Remove access plate from bottom of steering wheel. Unplug the yellow 2-pin connector.
4. Remove the access panels from each side of the steering wheel, then remove the torx bolts. Pull off the airbag module and set it in a safe place.
5. Unplug the connectors for the cruise control and horn.
6. Remove the steering wheel bolt. Remove the steering wheel using a steering wheel puller.
philadd is offline   Reply With Quote
Old 08-03-2006, 04:12 PM   #3
Crono139's Avatar
Default Re: Steering Wheel Removal. 2000 Accord SE. (philadd)
Crono139 is offline   Reply With Quote
Old 08-04-2006, 12:43 AM   #4
garaged_Si's Avatar
Thanks, The pictures will be helpfull.
Old 08-05-2006, 11:21 AM   #5
garaged_Si's Avatar
Steering Wheel Removel laxrider Honda Civic / Del Sol (1992 - 2000) 2 02-28-2008 06:03 PM
how do i safely remove my steering wheel w/ airbag?? sARCASTiC Tech / Misc 27 03-24-2005 05:29 PM
How to remove steering wheel with hub? SIR Spooner Honda Civic / Del Sol (1992 - 2000) 4 03-08-2004 08:50 PM
How to remove steering wheel??? 93EH6 Honda Civic / Del Sol (1992 - 2000) 6 12-02-2003 06:20 PM
steering wheel removal importneeds Honda Civic / Del Sol (1992 - 2000) 2 05-05-2002 12:20 PM
Tags
00, 02, 1999, 2000, 90, accord, change, honda, removal, remove, removing, replacement, steering, steeringwheel, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
